Activity › Forums › VEGAS Pro › H264 video for webpage
  • Odd Magne nilsen
    September 26, 2008 at 5:50 am
    ATRAC Audio
    AIFF
    FLAC
    MC AVC/AAC
    MC mpeg-1
    MC mpeg-2
    MP3
    OggVorbis
    Quick Time 7
    Sony MXF
    SPCA
    SW 64
    Video for Windows
    WMA
    WMP
    This is what I get. Have done “repaire” Pro 8,0c. And DVDA 5,0 is installed.
    Video to render is HDV.
    odd magne
    odd magne nilsen
    newbie
  • Odd Magne nilsen
    September 26, 2008 at 1:24 pm
    https://workingkelpie.net/aussie/asony.doc
    Copy of rendering window.
    odd magne
    odd magne nilsen
    newbie
  • John Rofrano
    September 26, 2008 at 1:30 pm
    > Have done “repaire” …
    I would completely uninstall both Vegas Pro 8.0 and DVD Architect 5.0 and re-install them. If that doesn’t fix it, contact Sony Tech Support. Something is wrong that these renderers are not being installed.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Rofrano
    September 26, 2008 at 1:40 pm
    You know… I should have looked at the picture you linked to before I made that last post.
    They say a picture is worth a thousand words and once I looked at it the problem was obvious. You are not using File | Render As…. You are using Render to New Track!!! That will only show you render options for file types that Vegas can edit.
    Goto to: File | Render As… and you should see the same options that I have posted.
    ~jr
  • Odd Magne nilsen
    September 26, 2008 at 1:48 pm
    Thanks a lot, now I got it 😀
    Do Sony AVC have any advantage over MainConcept AVC/AAC?
    odd m
    odd magne nilsen
    newbie
  • John Rofrano
    September 26, 2008 at 6:01 pm
    The advantage of the Sony encoder is that it supports mp4 files as well as wrapping MPEG-4 in an MPEG-2 Transport Stream (m2ts) and elementary video streams (avc). If you are making AVCHD Blu-ray files or Sony PSP files (on memory stick) I would select the Sony encoder.
    When rendering for the web like you want to do, I would stick with the MainConcept encoder. It is better at web formats that play well in Quicktime. You can try both since both support mp4 but in general I use the MainConcept for web work and Sony for AVCHD/Blu-ray work.
    ~jr
Page 2 of 2
