Activity › Forums › Blackmagic Design › H.264 Pro Recorder Test
Lauri Ahonen
September 8, 2011 at 12:58 pmWe are using Blackmagic Intensity PCI-Express cards for Studio purposes with TBC capable JVC VHS Deck.
We also have several of these – https://www.trustedreviews.com/Panasonic-DMR-EX83-HDD-DVD-Recorder_TV-recorder—set-top-box_review – top quality conversion and also supports RGB input.
M.D. Lauri Ahonen
Electronics and video processing enthusiast -
Félix Pouliot
October 15, 2015 at 12:01 pmHello Andrew,
I am quite new to this recorder and was wondering if I can use it whit my BMCC to have much smaller files?? I want to ba able to edit on a less powerfull computer. Do you just plug the box between your BMCC and the ssd and you get H.264 files directly when you shoot whit the camera?
Felix
Andrew Stone
October 15, 2015 at 3:42 pmFrom the SDI Out on the BM Cinema Camera you should be able to take that video stream and simply connect it to the H.264 Pro Recorder. Note, you will be recording into a computer via the USB cable from the H.264 device.
Sounds like you have the device. If so confirm that you can successfully record from the Recorder to your computer. I would be extremely leary of doing this on a professional and/or paid shoot unless you are certain you will get a continuous uninterrupted signal. Test, test, test.
Good luck.
-Andrew
Steadicam & Camera Operator
