Gregorian DATE/TIME data code & HDV (.m2t) metadata
Clay Miller replied 14 years, 1 month ago 14 Members · 20 Replies
Paul Pavlou
May 6, 2009 at 6:15 amI had the same problem. I then discovered a great little utility that embeds the datecode into the video. Its called DVdate and its free. Go to:
https://paul.glagla.free.fr/dvdate_en.htm
Colin Browell
May 6, 2009 at 8:00 amDvdate is standard definition DV only. The question is about HDV m2t files.
Devon Gam
July 3, 2009 at 7:53 amHi All,
I really feel your frustration about the date and time issue that grips us all in the forums. It is most frustrating that all cameras released today fail to come with software that emulates the camera’s capabilities itself; IE having the ability to display or not the date and time the video was recorded.I feel that there should be either one of two solutions that I hope the Manufacturers will READ and ACT upon.
1. It should be a simple feature of any and all PC based video player programs to identify the date and time video Metadata Information recorded when the video was originally captured and then act in the same way the video camera does in playback mode with an ability in way of a checkbox in the options menu to turn on or off the overlay data display. This will give the viewer the choice to view or not view. For those who provide the video to a client and want or need the video displayed with date and time visible then free issue of the video player software with the disk could be an easy option.
2. If the first point is not the simplest feature then the second option would involve rendering the metadata information onto the video to permanently embed the information at a position on the picture of the users’ choice.Video is captured in various media types and also in different file formats. A one stop shop software program that could cope with not only 1 avi file format or 1 mpeg file format but all versions of file would make millions $$$$$.
I recently purchased a Panasonic SDR-S26 which captures video onto a SD card. The camera will display, only once chosen in the camera menu system, the date and time on the flip-out screen and will display onto a monitor through the AV-out RCA cables. This is great to make a DVD of that video through an analogue capture card if loss of original video quality is not a real big issue.
A test I did to identify if the metadata was included in the file was;
I captured 2 minutes of video onto the SD card which created the following folder and file structure;
1 SD-Video/MGR_INFO/ and PRG001/
2 inside MGR_DATA (no extension), PRG_MGR (no extension)
3 inside PRG001/ was MOV001(mpeg file no extension but is MOD format), MOV001(MOI file no extension), PRG001.PGI, play from SD card on PC – no date and time but no surprise there. I burnt the entire SD_Video folder with all files inside with Nero as a Data DVD burn, transferred the disk to another PC and the file played OK but no date and time displayed. I then transferred the entire SD_Video to another SD card, put it back in the camera and played the video onto the screen with date and time displayed.My conclusion is that the metadata is included in one of the files that is recognised by the camera and the hardware with the software on the camera identifies this data and generates it as an analogue overlay on the video picture.
The camera also can connect to a Panasonic VW-BN1 (DVD burner). I connected the DVD burner to the camera via the supplied USB cable. The camera recognised the DVD burner connected and on the screed displayed Burn Disk or Play Disk. From the second SD card with the data copied to, I burnt the data to the DVD with the intuitive menu functions. From the burnt disk I played on my PC (without date and time displayed). I then put the disk back into the Panasonic DVD burner and the camera offered me to play the disk……. I chose “Yes” and here is the video now with date and time displayed….. Go figure.
Ashley and Martin “hair replacement program” ….. here I COME.
I post this in the hope that some nice camera manufacture technician will have a read it, grow a heart do some work and make our lives a little better.
DevonG
Dag Halvorsen
January 12, 2010 at 9:15 pmHello all,
I’m yet another satisfied Vegas user, but the date and time code from my clips (XDCAM EX1) does not appear in the media properties in Vegas.
It’s always frustrating to have to access the external drive and start clip browser while editing, simply to check when the clip was shot.
Such a simple (but important) problem, should have a simple solution. Why not?
br Dag Halvorsen, Norway
Daniel Stepnik
October 26, 2010 at 10:36 pmFWIW: I’ve tried adding metadata with Adobe Bridge and get a message that this feature is not supported. I can add metadata with all other video formats I use.
Kurt Outwater
October 11, 2011 at 6:50 pmHas anyone had any success in writing a script to put the gregorian date in a window burn?
Joe Gaziv
October 13, 2011 at 8:29 amWhen the clip is on the time line if you right click and ask for “properties” then “general” I think you can find the date/time the clip was taken under “modified”
Ronald Thomas
December 27, 2011 at 5:15 amI know this thread has been sitting for a few months, but I’m hunting for a way to rename captured m2t hdv files so the filename includes recording date/time and this is one of the most recent places anyone has discussed it. The closest I’ve come to finding something (other than spending $80 on DVMP Pro… just for that) is a utility that creates a subtitle file with date/time, geo position, etc. by reading that info from an AVCHD (.m2t) file.
In case it helps anyone else, the web site for that utility is here:
https://avchd2srt.webs.com/Next stop is to see if Sony has any way to suggest features for their capture tool in Vegas like “Capture File-Name Templates.” Maybe they’ll consider adding the ability to substitute a few basic variables (e.g. recorded date-time, tape position, etc.) into a captured file’s name.
Laszlo Kovacs
June 4, 2012 at 10:59 amHi, this is just for an update.
I have Vegas pro 10.0e and capture from a HVR-v1.
I get proper date/time stamps in deatailed view of media bin.Cheers
Laszlo Kovacs
Regards
K.L.
Clay Miller
August 15, 2012 at 9:25 pmFour years after the original question, I have figured out a simple work-around for this. When capturing through a firewire, the date/time does not show up on the computer in the software. However, if I go from my camera to another camera using an RCA cable, then from the second camera into the computer by firwire, it works! The date/time stamp is right there on my capture.
