Activity › Forums › Adobe After Effects › Green Screen Dancing Edge Pixels (After Effects CS6)
Steve Bentley replied 8 years, 5 months ago 3 Members · 44 Replies
Mark Whitney
March 26, 2018 at 2:56 pm[Steve Bentley] “Ok that footage is miles cleaner than the one you uploaded before. However it’s still pretty noisy.”
That’s what I’m seeing as well.
Matt, what ISO were you using?
Matt Dodds
March 26, 2018 at 3:59 pmI am using ISO 400, since I know that I normally get lots of grain! I try not to go any higher!
Matt Dodds
March 26, 2018 at 4:34 pmYou file looks great. I love how it looks more clear and I did show my co-worker and she thought it looked great as well. I never would have thought to do it that way. Our teacher showed a movie trailer that used 100% rotoscoping, but they never showed us about it. If it is just a mask with a moving keyframe, then I think I should be able to do that. Is there a tutorial regarding soft rim mattes and inner and outer feather masks?
Is there a better rendering file to use for transferring and exporting?
Most of the tutorials I have seen show the Keylight and the cleaning the spill in the keylight and that is it. Our teacher kind of did that as well. Not many tutorials show the levels it takes to do green screen work, like your comp. The tutorial I showed in the first post is the one I used and it helped for the most part, but the masking the hair line and matting other things like you post is something I would have never done, since I am not used to using AE.
Since I am a one man person, I was the only one there recording, but I will be having the person farther away from the screen and the camera. I will have to zoom in some, but I will have them farther away from the screen and camera. I only had one light on the person and 2 on the green screen, so I will need to get more lighting. The way I came in to do the clapboard, there was not light, but I understand about me taking up the light completely, since I was in the way. My camera doesn’t pick up that much light, so I know that I soaked up all the light.
I don’t want noise, but I am stuck with it, since my camera doesn’t pick up as much light as I wish it did. I am assuming it’s my lens, but I just don’t get enough. When it comes to my set up, it’ll be able the same. It is a video bio for the vets, for clients and referring vets. I want it clean and bright and those are my issues. If I can get a better camera body, more lighting, and set up the vet farther away from the green screen and farther away from the camera, I think I would be able to chroma key it better, but as a one-man team, that is the only one that knows about video, it’s difficult to get ideas and help, that is why I came onto here, after researching a lot.
I do want to thank you Steve for all your help. You have taught me some important things, that I never knew in the first place. I look forward to doing these techniques and tips, as I think I will be able to get a better/cleaner key out, if I follow them. My next goal is to get some more/better lighting. I am wanting to get some LED lights, that way I am able to shine it out more.
If I have any questions or need help, I won’t be afraid to ask you, as you have been really nice and super helpful!
Steve Bentley
March 26, 2018 at 11:17 pmOk, at the risk of elevating the ire of the community and lengthening this topic….
I hadn’t actually watched that youtube tutorial in the initial post until now (since you mentioned it again).
Where do I start…. I haven’t yelled at TV for a while but that gave my lungs a good workout!I never like being negative in these forums because it doesn’t help anyone, and because there’s never one right way to do something. And often, when investigating even dubious techniques, even us seasoned pros can learn a trick or two.
Buuuutttt…. There is just so much questionable information in that tutorial. So much so that the instructor doesn’t seem to know how to use AE in some areas. At one point he decides to use another layer as a matte. Since forever we have this thing called track matte that lets you pass the layer below through the layer above in either alpha or luma mode. While his technique is not wrong , it sure is a long way round a simple every day occurrence, and his technique is one we haven’t used since AE was called COSA. So that makes me wonder where the rest of the info has come from and his level of expertise.
Anyway getting beyond that little nit to pick.
The first issue could be classed a preference, but using full-red to check a key – any full chroma will overload your eyeballs and your monitor. You will not be able to see subtle issues in the matte edge with your cones screaming to turn down the volume and your monitor being pushed to the limits of its gammut. In addition, any two full-chroma primaries next to each other (red/Blue, Red/Green, Green/Blue) can vibrate in the eye (especially red/Blue – I can explain why if you like but its not important here)
His method for recoloring the screen to make it easier for Keylight to see…. Anytime you add a color correction or level trim or compression, or even change the color space, you are losing or transposing information. You can’t make more of what was there you can only crush it or invent it. Its like yelling at a person with a hearing aid. It kind of overloads a delicate system put in place to detect subtle things and you end up warping or replacing the information.
When we do film transfers we go to great lengths (enormous lengths, these companies spend month getting LUTS just right to tease the most out of the footage) to ensure that as much of the color of the screen is preserved, because even in a $1500 an hour grading suite you are loosing or shifting information and every time that happens the key gets worse.
There are subtle little roll offs between the green of the screen and the person in front of it. The keyers are designed to pick up those subtle differences and work in magical ways to determine what is screen and what is human; pushing and pulling on feathered edges and gentle blurs, even keeping but desaturating greenscreen pixels and letting them play as foreground pixels. By changing the color of the screen you are forcing colors into those subtle areas in ways that are more heavy handed than a keyer would and without control of that roll off. A keyer doesn’t care whether it sees a particular color, it only cares about the chroma separation between that specific color and things that are not. You can use keylight with green or blue or red, or beige or skybluepink if you want, but use it with the color that came on the virgin footage. You are also killing the grain structure when you stomp on the screen color – this is great for reducing the noise, but noise is detail.
Will his replace color technique produce a sharp key with less issues? You bet! Will it be the most accurate key and keep all the little feathery wispy details and show you his outline right to the last pixel of him? Not on your life. If you used that technique with something like water being poured into a glass (all on green screen) you would end up with a posterized mess.Then there’s the whole matte math done with, among other transfer functions, the Lighten. Instead of describing how lighten works across a range of uses, you just have to use it for a while in compositing to realize it has a very narrow niche. Try using it instead of screen or overlay or a few of the other blend modes that are used daily. It creates harsh roll offs which look sort of posterized. When applied to mattes or the product of mattes its not going to be the best and will surely wreck those subtle rollsoffs the keyers were designed to deal with. Then he adds a blur to overcome the harshness all his monkeying added. You could have probably added the blur to the initial keylight matte and then crushed it and come out the same. But again, its not going to preserve all the little edges that make a comp look real vs pasted on top. If you have harshened an edge and then softened it, you have changed that edge irrevocably, an no CSI type software is going to be able to resolve the original details again. ( I have a friend in Forensics who says CSI is is favorite comedy show, I’m starting to feel the same about this youtube video).
I’m sure there are situations where some of those techniques might be useful but to put them forwards as “here’s how you pull a key”, is doing a disservice to all the things keying software can do when used properly. And I think this shows in his final comps. Especially the guy with the glasses at the end. I don’t have any clients that would accept that boiling bubbling key where the stem of his eyeglasses disappears.
Notice I’m not posting this rant to his youtube page. I only spouted because you are having troubles, and this video you brought forward is going to steer you wrong.
