Activity › Forums › Adobe Premiere Pro › Graphics problem after Yosemite upgrade
Michael Belanger replied 10 years, 5 months ago 15 Members · 32 Replies
Charlie Austin
February 18, 2015 at 6:35 pm[Paul Jones] “Sadly mine is still the same even after all the updates”
Same here. I’d be happy to blame the OS, Nvidia, or other apps etc, but this only happens when I run Pr. If it’s running on it’s own, it may take some time to appear, with other video apps running it happens fairly quickly. It probably is a CUDA thing, or dual monitors, or something, but only Pr sets it off…
~ My FCPX Babbling blog ~
~”It is a poor craftsman who blames his tools.”~
~”The function you just attempted is not yet implemented”~ -
Michael Belanger
April 15, 2016 at 12:37 pmYes indeed… if it ain’t broke don’t fix it. But unfortunately the powers that be really force you to upgrade because some software simply won’t run on older OS. The original days of editing meant ONE company supplied you with a complete solution but these days you are relying on a number of companies and they don’t always talk to one another.
Bottom line, if you got a working system then use that unless there is some pressing need to change. FCP 7 was quite reliable and Premiere in software only mode for mercury playback is supposedly rock solid. The issue seems to be the handshake to the cards and once that is corrupted it buggers the whole system. I am guessing some sort of memory issue that pushes the card to the limit in premiere and then once it is confused it carries onto the glichiness in the day to day system.M Belanger
Dandelion Picture and Sound
