Activity Forums Panasonic Cameras GPS on HD
  • Ethan Sigman
    June 25, 2009 at 5:24 pm
    Mark,
    will the 900 push gps meta out the HD-SDI? can you hook an hpg20/”gear” to the hd-sdi, record to .mxf with meta for gps? you would also get the added advantage of recording avc-intra if you used a hpg20, but you could use an hpg10 and record dvcpro if you need to match other footage shot with 900….. still not sure the gps works the way you need it but that might get you the data…..
    Ethan
    http://www.EZSproductions.com
    http://www.VaricamUser.com
    http://www.ProductionMeeting.com/profile/EthanSigman
  • Andy Kolcz
    September 3, 2009 at 6:09 pm
    Ray,
    I found your post through a Google search. We are using a fairly expensive commercial system (h/w and s/w) to record GPS signal on the audio track and then view & process the video with a synchronized map “live” at the office. It is quite an expensive system and I’ve been asked by clients to see about any cheaper alternatives. You mention the cost of $400, could you perhaps post a link to the vendor?
    Thanks a bunch,
    Andy
    Just another traffic engineer…
Page 2 of 2
