Activity › Forums › Apple Final Cut Pro › Globally change text parameters
  • Mark Smith
    March 20, 2017 at 7:33 pm
    Brian-
    You may not understand the situation fully–I have about 10 lower thirds in a small project that were based on a stock text FCPX template. text background parameters are published with that template.
    What I want to do is select instances of the text template in the time line index , which when I do, I see in the browser as x amount of items selected. I do see the text template background color as active and can change the color. When i do change the text background color, only one lower third background changes and the remaining text backgrounds are unchanged.
    No compound clips are involved in this at all.
  • Andreas Kiel
    March 20, 2017 at 7:44 pm
    Mark,
    You’re right.
    I’ve never been in a situation like that, so I don’t know whether it has been like that since day one.
    You should file at least a feature request.
    in the meantime: to speed up your job to change multiple clip colors create a custom palette.
    – Andreas
    Spherico
    https://www.spherico.com/filmtools
    “He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil
  • Brian Seegmiller
    March 20, 2017 at 8:28 pm
    Yes, I understood your issue. Just trying to think of a better way to do it without to much trouble. Of course I think of it after the fact sometimes on my projects. For this situation I would have created a compound clip with just the colored bar and then add the individual text later for each one. If I change my mind on the color, I can do it by just changing one compound clip. If the text stays the same for all lower thirds as well, include that in the compound clip.
  • Mark Smith
    March 21, 2017 at 11:02 am
    Filed a feature request to Apple.
  • Doug Metz
    March 21, 2017 at 2:09 pm
    [Mark Smith] “Filed a feature request to Apple.”
    I filed it as a bug. ;^)
    Doug Metz
    Anode
  • Mark Smith
    March 21, 2017 at 2:45 pm
    I think you’re right- its more of a bug than a feature request.
Page 2 of 2
