Activity Forums Adobe Premiere Pro Glitch During Dissolve?
  • Jona Taylor
    January 26, 2014 at 12:43 pm
    Nesting… who would have thought?
    Thanks again Ann 🙂
  • Alex Elkins
    January 28, 2014 at 6:45 pm
    I’m just going to step in to make an alternative suggestion. It’s good to hear the nesting solution worked for you, but it’s in not a solution that would be advisable for everyone (for example, anyone going from offline editing in Premiere to online/grading outside of Premiere).
    My first impression when I read your original post was that your render settings (XDCAM) are exactly the type of codec known for these sorts of issues. So my suggestion is to change your render settings (also known as preview settings) to one of the following:
    • ProRes 422
    • ProRes 422 HQ
    • Uncompressed 8 bit
    • Uncompressed 10 bit
    Obviously I’ve not got your project in front of me but I suspect if you tested it this would also fix the problem. There’s not really a good reason why nesting the clip should fix this issue anyway – it sounds more like a workaround for a Premiere bug than anything.
    Alex Elkins // Editor & Colourist
    alexelkins.co.uk
    @postbluetv
  • Jona Taylor
    January 28, 2014 at 6:49 pm
    Hello Alex!
    Big thanks for jumping in here 🙂
    I’ll give you suggestion a try and report back just as soon as I can confirm.
    Jona
  • Jona Taylor
    January 29, 2014 at 3:40 pm
    I rendered the timeline in ProRes and the problem has stopped. It is now not necessary to nest the clips to stop this glitch problem.
    Another big thanks to Alex who provided the solution to the problem.
    This site, and the people who continue to contribute to it are invaluable!
    Jona
Page 2 of 2
