Activity › Forums › Apple Final Cut Pro Legacy › General Error 34 wth is this thing
Jeffrey Rikhotso replied 10 years, 9 months ago 19 Members · 20 Replies
Tamara Najm
September 26, 2010 at 3:49 amHe’s absolutely right, if the “in” point is set at the end of the sequence you will get the General Error or General Error (34) message, depending on how you convert it. It’s not a matter of the disk being full.
Dave Williams
September 27, 2010 at 7:17 pmSo glad I read this thread. I cleared my in and outs and sure enough…PROBLEM SOLVED.
Liz Smith
March 17, 2011 at 2:06 pmthank you for posting this, I had the same issue and this was exactly the cause.
Philip Peel
May 14, 2011 at 2:22 pmWonderful worked wonderfully!
thank you so much. I was about to order a new drive.
thinking about it I may order one anyway. 🙂
David Usner
June 15, 2012 at 4:42 amWow. That was simple. Don’t know how I got that IN point at the end of the timeline but there it was. Thanks.
David Usner
http://www.usner.us -
Catherine Tosko
January 28, 2013 at 6:11 pmdo i get the record? two days before i discovered the beginning was at the end…doh…
Philip Leech
March 9, 2013 at 7:08 pmWell my hard dive is certainly not full and my in and out points are set correctly. Still getting the error 34 message when trying to export, plus the resulting file has no video, only audio.
