Theo Van laar
November 24, 2009 at 5:01 pm‘Now go complain to Boris that they need to “officially” support Vegas Pro 9.0! 🙁 ‘
I did sometime ago. And Peter Mcauley from Boris FX replied with:
‘To the best of my knowledge, nothing has changed with regard to the Vegas host passing the plug-in any sequence data / alternate frames in time. Until that happens we can’t perform the stabilization. You can stabilize the clip using RED in standalone mode though, but you probably know this already.’And yesterday, when I mentioned your solution, Matt Mullen (also from Boris FX) said:
‘Theo,Yes 9 is fully supported as long as you are not running a 64 bit app.
The vegas 8 install option will install into 8 but you can point it to the version 9 folder or move them manually as you stated.’
Theo
