Activity › Forums › Web Design (WordPress, Joomla, etc.) › Full Page Overlay – FAO Abraham
  • Abraham Chaffin
    December 23, 2008 at 3:46 pm
    You would use the javascript function like this:
    function clicker(){
    	var thediv=document.getElementById('displaybox');
    	if(thediv.style.display == "none"){
    		thediv.style.display = "";
    		thediv.innerHTML = file_get_contents("https://www.creativecow.net/404.html");
    	}else{
    		thediv.style.display = "none";
    		thediv.innerHTML = '';
    	return false;
    The changed line is the line:
    thediv.innerHTML = file_get_contents(“https://www.creativecow.net/404.html”);
    Abraham
  • Don Noray
    January 14, 2009 at 9:08 am
    Hi Abraham, first I would like to thank you for the tutorial. I am creating a site for the church I attend and I tried the overlay of a flash video but I can see the images behind the flash. I set the wmode to opaque but to no avail. Can you check it out for me please?
    https://dnoray.com/test.html
    This is the direct link to the swf file https://dnoray.com/fla/message1.swf
  • Abraham Chaffin
    January 14, 2009 at 4:00 pm
    Remove the wmode parameter all together. the wmode=opaque is causing it to pick up transparency. Just remove the wmode parameter.
    Abraham
  • Don Noray
    January 17, 2009 at 8:46 pm
    Hi Abraham,
    Thanks for the response but I removed the wmode and it is still transparent on the mac platform but is fine on pc. Is there any workaround to this?
  • Jason D’andrade
    January 25, 2009 at 1:05 am
    I would like to use the overlay and have a full html page load in the center of the overlay. The file_get is not working for me. Is there another way to do it without PHP or Ajax? Your insight would be greatly appreciated.
    Open Window
  • Steve Mara
    January 28, 2009 at 8:41 pm
    Hello Abraham,
    Your Full Page Overlay code is what I have been looking for, its perfect! Can you help me call the function from within a flash file.
    I am trying this:
    on (release){
    getURL("javascript:'return clicker();'");
    and the new page just says return clicker on it, the div doesn’t get activated.
    Many thanks,
    Steve
  • Abraham Chaffin
    January 28, 2009 at 9:08 pm
    Try this:
    on (release){
    getURL("javascript:clicker()");
    Abraham
  • Steve Mara
    January 28, 2009 at 11:04 pm
    Sweetnesss!!!
  • Daniel Lahey
    April 30, 2009 at 1:50 am
    I am unable to create a popup form that doesn’t inherit the opacity of the ‘displaybox’ div. In other words, the form and all of its elements inherit the 50% opacity of the ‘displaybox’ div. I’ve tried setting the opacity of a div in the innerHTML to 1.0 (I’m on Firefox 3.x), setting the opacity of the elements, setting the z-index higher than that of the ‘displaybox’ div, etc. Help, please!
    Cleverness is serviceable for everything, sufficient for nothing ~ Henri-Frederick Amiel
  • Daniel Lahey
    April 30, 2009 at 1:53 pm
    I forgot to mention that I am on Mac OX 10.5.6 (Intel Mac).
Page 2 of 3
