Activity Forums Apple Final Cut Pro FS700 Raw Files and FCPX
  • Jeremy Garchow
    June 11, 2015 at 9:16 pm
    The Sony utility will only work if it’s recorded with Sony RAW recorded on the AXS-R5. It won’t work with Odyssey files.
    I’d transcode in Resolve as well. It’ll be much easier. You can even to a log encode and use a LUT for preview and grade in X when complete. If you ever need to go back to the RAW, you can always do so in Resolve.
  • Scott Witthaus
    June 13, 2015 at 2:24 pm
    Actually, they are thinking about going with an Epic and have RedCine do the transcode to ProRes proxies done by the finishing house. And that is totally cool by me! However, I have heard rumblings about Red and hot and humid environments not playing well together. Anyone else heard this?
    Scott Witthaus
    Senior Editor/Post Production Supervisor
    1708 Inc./Editorial
    Professor, VCU Brandcenter
  • Oliver Peters
    June 13, 2015 at 2:36 pm
    [Scott Witthaus] “I have heard rumblings about Red and hot and humid environments not playing well together.”
    Yes, that’s the case for sure with the original RED One. There are anecdotes about DPs putting frozen bags of peas over the camera housing to keep it cool. It might not be an issue with Epic.
    That being said, I’ve worked on a number of indie film projects shot with RED Ones in Florida in summer and there weren’t that many problems. Most DPs know how to handle the camera. The only actual issue we had on one project was a scene shot in a hot dry cleaner shop, which is pretty extreme. Those clips had digital hits throughout every set-up. On those, I was able to force a transcode on most takes and cut around the hits. Enough coverage survived to cut a scene together.
    Otherwise, I haven’t run across too many actual issues and there’s a lot of RED bing shot in Florida.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Scott Witthaus
    June 13, 2015 at 2:48 pm
    [Oliver Peters] “It might not be an issue with Epic.”
    Lets hope so. Not sure there are enough frozen peas in central Louisiana in July….
    Scott Witthaus
    1708 Inc./Editorial
  • Oliver Peters
    June 13, 2015 at 3:55 pm
    [Scott Witthaus] “Not sure there are enough frozen peas in central Louisiana in July….”
    Stick it in a bag in the beer cooler for awhile. I’m sure there are plenty of those there 😉
    (I’m not a DP, so I accept no responsibility if some idiot takes this advice seriously!)
    – Oliver
    Orlando, FL
Page 2 of 2
