Activity › Forums › Adobe Premiere Pro › Frustrating bug in Premiere cc
  • Matthew Ross
    December 19, 2019 at 2:42 pm
    Huh, that’s interesting. Here’s my view in Premiere 14.0 (which is from CC 2020, but I don’t remember it being different in CC 2019):
  • David Moore
    December 20, 2019 at 7:48 am
    What’s interesting is that you don’t seem to have a work area. I do, and I get “render work area” instead.
    I don’t create a work area, that just happens automatically, and in fact, I’ve never really discovered what it’s for.
    I’ll try to remove the work area later and see what happens.
  • David Moore
    December 20, 2019 at 8:23 am
    Right, so I found where the work area bar can be turned on and off (the hamburger menu next to sequence title), and then I get render in to out again…
    I still think that you should be able to highlight something and do “render selection”. However at least it’s now possible to render a portion again.
    One can use X to select what’s under the playhead, however that tends to require track targetting to be set differently to how I use the targetting.
  • Greg Janza
    December 20, 2019 at 4:29 pm
    If you take advantage of the proxy workflow you can play back all media at full res without any rendering and without so much as a hiccup in play back and the only rendering will occur on export.
    https://www.linkedin.com/in/tmprods
    tallmanproductions.net
  • David Moore
    December 20, 2019 at 4:41 pm
    I am using low res proxy files to enable fast editing and scrubbing etc.
    However I’m not aware of a full res proxy which then plays back all effects/layers without any glitches.
    The closest I ever found was converting to a faster codec, eg propres, however that turned my 40GB footage into 14TB, so was not a in really a practical solution.
    Care to elaborate?
  • Greg Janza
    December 20, 2019 at 8:17 pm
    I was referring to full res as in not having to set play back to 1/2 or 1/4.
    With proxies there’s really no need to render at all.
  • David Moore
    December 27, 2019 at 10:05 am
    But proxies are not full res, so you can’t check things in final quality.
Page 2 of 2
