Activity › Forums › AJA Video Systems › Freerun Broken?
  • Jeremy Garchow
    August 14, 2007 at 2:33 pm
    Yep, that’s exactly what I get sometimes too.
    By the way, I have my CP set to black all the time for default output.
    Jeremy
  • Jeremy Garchow
    August 14, 2007 at 2:46 pm
    Are you routed straight to a deck, or other?
  • Rory Hinds
    August 14, 2007 at 2:58 pm
    Straight to the deck.
    I’ve tried turning EE off and on but this has no effect.
    I’ve also tried it with my Digibeta and Kona synced to house sync black and burst and the AJA control panel set to Ref In… but still the lines remain.
    The only way I can get rid of the lines is to have only the input or output from the Kona connected to the Digi one at time.. if you connect both you get the lines.
    They say it shouldn’t effect capture and playback but I had it doing just that… getting a weird field alternating issue which is when I first contact AJA and a replacement board was sent out.
    I hope this can be fixed as its an issue.
    Rory Hinds
    mine
    http://www.minefilms.com
  • Rory Hinds
    August 14, 2007 at 2:59 pm
    Rory Hinds
    mine
  • Jeremy Garchow
    August 14, 2007 at 3:14 pm
    See that would mean to me some sort of feedback, turning EE off would solve that though.
    Did you try the suggestions you posted earlier?
  • Rory Hinds
    August 14, 2007 at 3:17 pm
    Yeah I think its feedback for sure.
    Yes I tried all the instructions and still haven’t solved this.
    I’m talking with AJA support and hopefully they see this is a problem and can fix is.
    Rory Hinds
    mine
  • Jeremy Garchow
    August 14, 2007 at 3:27 pm
    Let us know how it goes.
    Jeremy
  • Rory Hinds
    August 14, 2007 at 3:30 pm
    will do, would be interesting to find out how Sean gets on too…
    Rory Hinds
    mine
  • Sean Oneil
    August 14, 2007 at 4:52 pm
    This is a screenshot of what I’m seeing:
    https://www.crosscreekentertain.com/ETT_Noise.jpg
    It looks like this when I open it no matter what the capture/plaback setting is, and no matter what is hooked up. Even if nothing is plugged in.
    Freerun or Ref In (from a working blackburst) makes no difference.
  • Jeremy Garchow
    August 14, 2007 at 6:41 pm
    Oooooooo, pretty.
    Jeremy
Page 3 of 4
