Activity › Forums › Apple Final Cut Pro Legacy › FREEBIE Motion clock template
Peter Wiggins
November 29, 2005 at 7:19 pmChris,
No problem, enjoy using it!
PeterNow editing the feature “BEYOND THE MARGIN”
-THE LIFE AND WORK OF JOHN A.ALONZO -
Richard
November 30, 2005 at 11:30 amHi Phil,
Not so strange that your nested sequences are changing fields.
“Clock face DV Anamorphic F1” has Field Dominance: Upper, while “DV Clock Field 1 nested” has Field Dominance: Lower!! -
Phil Stone
November 30, 2005 at 12:13 pmRichard
Thanks for that it was driving me mad. Although if you look in sequence settings it said upper but if you look in item properties it said lower, I have now changed it to upper
Richard
November 30, 2005 at 12:29 pmPhil
In my version of FCP( 🙂 ) both are consistent, in setting as well as in properties: Lower Field
Phil Stone
November 30, 2005 at 4:30 pmRichard
Very Interesting I junked prefs and looked again at original project and still get the same result.
I will have to watch out for that in future although I would not normaly change field dominence mid project
I did in this case to check things out. -
Steve Mackay
March 28, 2013 at 2:10 pmHi Peter,
I clicked on your link peterwiggins.com and nothing is coming up? just the word ‘Index’
I require a Clock Ident for my work and you seem to have created one yeah for free download?Steve – smart-cookie.eu
