Activity › Forums › Adobe After Effects Expressions › free wiggle, rubber, bounce, throw, inertia expressions i find useful
Scott Green replied 13 years, 2 months ago 11 Members · 16 Replies
Dan Ebberts
August 20, 2012 at 11:21 pmThat’s pretty strange. You could try replacing the last part of the expression with this:
if (n > 0){
try{
v = velocityAtTime(key(n).time - thisComp.frameDuration/10);
value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
}catch (err){
value
}else
value
That should stop the error message, but it might give you a strange glitch where the value suddenly pops back to the pre-expression value, so watch out for that.
Dan
Layne Haacke
August 21, 2012 at 1:23 pmwith a quick test, that seemed to work.
I’ll watch for that glitch.Thanks
Michael Wilfong
August 30, 2012 at 9:14 pmI’m having the same issue ONLY in CS6 too!! I haven’t found a way to fix it either. I’ll try to swap the last part as Dan mentions but I’d really like to know what’s happening here. Perhaps there is a fix in the works??
Scott Green
July 4, 2013 at 3:45 pmIs there an expression that will make a wire sway?
Like a skipping rope, say you’re turning the skipping rope and then stop turning, the rope will sway.
I’ve animated this USB lead coming in from the left and connecting to the USB port. I used the puppet tool to make the wire look a bit more organic as it was approaching the port but I think using an expression like this could make it look really nice and natural looking.
Thanks in advance.
Creative Multimedia Design Manchester | S©tt Green | Splurj
Chris Wright
July 4, 2013 at 11:23 pmI don’t know exactly how you want to perceive the cord, but one way I imagined was the cord closest to the usb port was slightly stiff and the far tail was way looser. I would apply starch to the front and the tail was much more waggy using this elastic example.
https://www.motionscript.com/design-guide/elastic.html
or if you want to overshoot the keyframe
https://www.motionscript.com/articles/bounce-and-overshoot.html -
Scott Green
July 5, 2013 at 7:47 amThe Calculation Overshoot expression worked a treat, many thanks 🙂
