Activity › Forums › Compression Techniques › Framerate Conversion: 23.98 Timeline With Some 29.97 Clips
  • Andrew Saliga
    March 23, 2009 at 5:38 pm
    Any tips on framerate conversion through Compressor vs. AE? There are some effects shots that were made in AE at 29.97.
    -Andrew Saliga
  • Matt Schulze
    March 25, 2009 at 8:31 pm
    As far as the up/down conversion of SD clips are concerned, I took the following approach.
    Edited everything in an HD timeline, imported the SD clips but treated them just as place holders.
    Then downconverted to SD, put the program in an SD time line and then replaced the “place holder clips” with their original SD source clips.
    That way I avoided the up/down conversion problem. since you only have 15% SD, it shouldn’t be that much extra work.
    Just my two cents.
    Matt
Page 2 of 2
