Activity › Forums › Creative Community Conversations › Frame.io meets Adobe Premiere Pro
Andrew Kimery replied 10 years, 4 months ago 12 Members · 40 Replies
Andrew Kimery
March 25, 2016 at 6:18 pmHave you tried opening up the XML in a new, Temp PPro project, closing that project, opening up your PPro Project and using the Media Browser to import what you need from the Temp project. I think that should do fix the duplicate media issue.
It’s a kludgy workaround but it might be less annoying then having duplicate media in your project.
Walter Soyka
March 25, 2016 at 6:20 pm[Jeremy Garchow] “Famous last words.”
I’ve ordered them inscribed on my tombstone.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Jeremy Garchow
March 25, 2016 at 6:22 pmI haven’t.
What I do now is just duplicate the project.
– So I have an original project.
– A consolidated project.
– And then a consolidated project_relinked
I am looking to remove Pr form this workflow, but I haven’t found the best way so far. Resolve is kind of an option, but it used to wreak havoc on audio. It’s getting better, though.
Andrew Kimery
March 25, 2016 at 6:32 pm[Jeremy Garchow] “I am looking to remove Pr form this workflow, but I haven’t found the best way so far.”
Yeah, it kinda sounds like you are being forced to use a sledge hammer to swat a fly because you don’t have any other options.
Oliver Peters
March 26, 2016 at 12:25 amAdobe offers extensions to the UI, which enable third parties to add capability within the app itself. Simple extensions for Premiere include PDF Viewer and Post Notes as a starter.
https://www.primalcuts.com/site/
https://postnotes.ioWe After Effects you have a bunch and these tend to work like very sophisticated macros. For example, Type Monkey and Layer Monkey.
Extensions is a great way to extend the power of the UI, which is something FCPX could use as well.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
Andrew Kimery
April 11, 2016 at 4:45 pmFrame.io panel from Adobe just dropped.
Below is a write up about it (as well as a new video which explains it in more depth than just the teaser from before).
https://www.provideocoalition.com/frameio_premiere_pro
Erik Lindahl
April 11, 2016 at 7:57 pmThe problem with this approach is that the files are unreadable by some applications.
Oliver Peters
April 14, 2016 at 12:36 amWipster is also getting into the act:
https://wipster.io/blog/wipster-adobe-premiere-pro-a-revolution-in-collaboration
– Oliver
Orlando, FL
Andrew Kimery
April 14, 2016 at 1:19 amI don’t know if it’s new or not but Kollaborate has a panel too.
https://www.kollaborate.tv/resources
Andrew Kimery
April 19, 2016 at 4:43 pmAnd Promax released a panel at NAB.
https://promax.com/workflows/online-editing/
2016 is turning into the year of the panel for PPro.
