Activity › Forums › Apple Final Cut Pro Legacy › frame jumps or duplicates when adding name super
Jeremy Garchow replied 19 years ago 3 Members · 15 Replies
Jeff Wilmes
September 10, 2007 at 8:07 pmDo you know the name of the doc, or where to find it.
Also, I gave the quicktime blur a go and it’s working. I’ll look for the doc and give that a try if it’s easier than adding the filter, then upgrade as soon as this is over. Thanks for all the help!
Jeremy Garchow
September 10, 2007 at 9:09 pmI remembered it wrong, this tell you what to do after you have updated to 5.1.x
https://docs.info.apple.com/article.html?artnum=303950
Follow dhiedel’s advice. He’s all over it.
Jeremy
David Heidelberger
September 10, 2007 at 10:14 pmThanks Jeremy,
This one bit me hard on a project last year and I spent a couple days figuring out what made this bug tick. It was amazing, you could lay a clip on a timeline, drop an effect on, and suddenly the frame would jump to something else entirely. So glad I’m through the crossgrade now.
– David
Jeremy Garchow
September 11, 2007 at 1:43 amYes, this trick is handy for a number of things. There’s a bug in 10 bit scaling for FCP and this same trick works to cure it.
Jeremy
