Activity Forums Web Design (WordPress, Joomla, etc.) Formatting text in a dreamweaver CS5 table
  • Fernando Mol
    February 16, 2012 at 2:37 am
    OK. You are using a SpryTooltip. This changes the panorama, because you probably have an specificity problem.
    This is the rule that is defining the color of the text in your table:
    #SongLinerNotes td {
    color:#333;
    What you want is to change the color of the text in some table cells.
    You need to create a class for them. So, to avoid any specificity problems, add a very specific compound rule for the class in that table. Something like this:
    #SongLinerNotes td .differentcolor {
    color:#666;
    Then, add the class to the table cells you need to have it.
    That should work
  • Ross Smith
    February 21, 2012 at 8:57 am
    Edit the table using Add or edit accessibility. We make good use of it at mikannie.com.au
  • Douglas Welbar
    September 15, 2014 at 6:55 am
    try this…CSS Formatting on Tables
    Douglas
Page 2 of 2
