Activity › Forums › Adobe After Effects › Flicking problem in the End Credits
Chris Monaco replied 13 years, 7 months ago 7 Members · 14 Replies
Ear-junior
June 8, 2007 at 7:50 pmHaving some success with this tip. Is the frame factor in NTSC 30 fps or 29.97 as opposed to the PAL 25 fps used in the example?
Sebastian Manger
January 7, 2008 at 9:04 pmin my project occurs the problem that the animation of the title is over before the composition its running in is over.
anyone knows how to solve the problem?
would be great.
thanks alot! -
Benjamin David
September 3, 2012 at 4:26 pmSorry if this is an obvious question but i have very little experience with maneuvering around AE – how exactly do we change the frame rate or pixel/integer? I understand the explanation…but I don’t know what in after effects I should be adjusting to make sure the integer is a whole number.
Chris Monaco
January 14, 2013 at 8:30 pmHey,
I tried using this script and everything seemed to be animating fine just as long as I kept it at 2px per sec. However i need it to be twice as fast, so I have it set to 4px per sec. The motion it self is consistent however there seems to be some vibration on the edges of the text as it animates.
I figured it was an aliasing issue so I added a .05% directional blur and reduced the white color of the text to 75% (not the opacity, the brightness of the white).My comp settings are:
23.976 FPS
1998×1080
Duration: 0:04:35:00The text layer comp height is 25232px
This credit roll will be played back progressive not interlaced.
I tried to attach my AE project to this post, hopefully it works and you guys can see what I might be doing wrong. This version of my project is a reduced example with all the same settings of the real thing except the text is all dummy text.
The system I am watching it on is a FLAME, with a broadcast monitor.
It is strange that it moves consistently frame by frame yet it has a weird vibration look to it. Any advice would be appreciated!
