Activity › Forums › Apple Final Cut Pro Legacy › Flash (FLV) missing from export options
Tom Bell replied 15 years, 9 months ago 8 Members · 16 Replies
Elizabeth Bridenstine
February 17, 2010 at 9:47 pmI was able to fix this issue.
I upgraded to Snow Leopard and then had to downgrade back to Leopard. The FLV Component was deleted. I was able to find a backup FLV Component in my Previous Systems folder.
Thanks for the help!
Brian Rose
March 5, 2010 at 7:04 pmI am very confused being that I see the FLV COMPONENT in my QT folder and I still dont have the ability to export to .flv within QT, FCP7>Compressor. Theres simply no option. Im on Snow Leopard and FCP7. Please help!!!
Antoine Vuduc
May 10, 2010 at 9:52 pmAs i don’t use FCP, i give you a tip from simple user:
export in .flv is not the only way to make flv file…
Flash Player CAN play H.264… so you just have to export in H264 format and change ( yes ! ) the extension ( .mov often kept after export by the most like Quicktime 7 Pro )…by .flvfor exemple, in Quicktime 7 Pro, export your video in sequence with option H.264, you will obtain a .mov
Just change mov by flv and it will be oK.Hope that helps.
Karl Dyktynski
July 22, 2010 at 2:24 amI recently upgraded from CS3 to CS5 Production Suite and then Snow Leopard. (Macpro 2.66 Ghz). I then tried to export to FLV from FCP6 and the option was missing. I discovered the option was missing from compressor and QT pro also and the FLV component gone from the QT library. I went back through my time machine and it appears to have gone missing with the CS5 install.
Flash will playback an H264 file but if you need to create cue points in the video to trigger other events in flash you need an flv. For FCP users this means exporting from FCP and then encoding again with adobe media encoder. Not efficient.
I found the QT flv component and placed it back in the library. It exports as badly in FCP and QT as it did before. Compressor is the better option. I tried uploading the component here but it didn’t work.
In FCP the progress bar sits on 0% and you get the spinning wheel of death but it is actually working. In the finder you can see the file created and increasing in size over time, you just can’t tell when it’s going to finish until it does. I calculate the file size from the bitrate, wait and watch.
Hope this helps people
Tom Bell
December 3, 2010 at 7:50 pmHi there.
I have a same problem with FVV export component. I need to preserve transparency from final cut time line and only .flv seems to do it.
Could you eail me FLV.component file for QuickTime pretty please?
Many thanks -
Tom Bell
Many thanks
