Activity Forums Apple Final Cut Pro Legacy Firewire networking, yes, Mac & PC… a quick FYI
  • Firewire networking, yes, Mac & PC… a quick FYI
    Posted by Bob Woodhead on May 19, 2005 at 12:42 pm
    I’ve been using my PC as “near-term storage” for capture files. I’ve got a TB SCSI RAID, but when that fills up, and I don’t want to take things offline, I transfer the not-needed-right-now captures to a XP box that’s loaded with big, cheap IDE drives. I just drag a capture scratch folder across the network onto the XP, delete off the RAID, and reverse when needed again. Sure it takes awhile (since I don’t have a gigabit lan) but I just let it go after hours, and it only takes a moment of “face time”.
    SO… something made me think about using Firewire, and after a bit of searching (there aren’t many articles it seems on Firewiring Mac & PC’s), found the answer. It works so well I decided to take the time to let everyone here know. Non-quantified results appear to be much faster than 100Mb lan, as actual transfer speeds through a switch, along with other random network traffic, are quite a bit slower. The firewire is on the 400 bus.
    Disclaimer: I’ve no idea about Tiger, it appears there are some who were using Samba/Sharepoints combo on Panther that now have issues on Tiger, and some are OK. Also, this only works w/ WinXP, not 2000, etc.
    1] Have Mac-PC sharing working already, preferrably using Sharepoints & Samba via TCP/IP [other methods *may* not work w/ this setup]
    2] OSX System Prefs / Network Port Configs – add a New connection, call it whatever, select Built in Firewire. Set IP address to something like 10.0.0.1 Subnet 255.0.0.0, ignore DNS & everything else
    3] WinXP: plug the firewire into the Mac. When “New Hardware” wizard appears, just cancel. In Network setup, select the 1394 connection, Properties, TCP/IP settings, set IP to 10.0.0.2 Subnet 255.0.0.0 (same scheme as Mac, natch), close.
    4] OK, here’s where it got a bit “grey”… after doing the above it didn’t work right away. So I disconnected ethernet & let the Mac/XP 1394 stay connected, and waited a few minutes. Shortly I was able to use the Finder Connect command to mount a share from 10.0.0.2 (the XP), using same user/pass syntax I use on ethernet connects.
    5] plug ethernet back in. I’ve found NO issues so far with anything else being adversely affected. My setup has Mac/XP 1394 going through a hub, btw. I’ve got a nice, permanent, 4-10 times faster than before, Mac/PC connection for the price of a 1394 cable.
    Your speeds may vary, side effects may include fewer purchases of expensive external drives.
    Bob Woodhead / Atlanta
    Quantel-Avid-FCP-3D-Crayola
    G5 DP 2G, 10.3.4, 3.5GB RAM, FCP 4.5, Aja IO, Huge 320R [raid3]
    Nick Meyers replied 21 years, 4 months ago 6 Members · 12 Replies
  • 12 Replies
  • Bryce Whiteside
    May 19, 2005 at 3:21 pm
    Okay I’ll nominate you for Geekdom–meant in a good way.
    Nice trick,
    Bryce
    Don’t worry Mr. B. I have a cunning plan…
    PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
  • Will Griffith
    May 19, 2005 at 5:18 pm
    thanks man. after IT blocked the macs from our
    PC network (security concerns) we were resorted
    to using flash drives and such. I just used this
    to connect 4 different G5s to PCs setting next to
    them and it works great. Much faster than I remember
    IP connection as well.
    -will
  • Bob Woodhead
    May 19, 2005 at 5:24 pm
    Don’t forget to tell your boss that the cost of all that high-speed connectivity was equal to…. oh…. the price of a new Intuos3 tablet. 😉
  • Will Griffith
    May 19, 2005 at 5:28 pm
    sounds like you would fit right into our
    purchasing philosophy. We have to be pretty
    creative if you know what I mean.
  • Shawn Bockoven
    May 19, 2005 at 5:57 pm
    Our solution for PC and Mac high-speed file transfers: Linksys SR2016 Gigabit switch ($300.00+-), installed new 10/100 NIC cards in the Macs and Dells ($30.00+-) and CAT 6 cable. I used the onboard gigabit cards for the gigabit switch and the 10/100 cards for WAN and Internet connectivity. Now all of our video files are transferred using the Gigabit LAN. Building this gigabit network for ten computers cost us just over $650.00 with room to grow.
    We are using Rendezvous/Bonjour for small file transfers after setting the systems to use the gigabit connection first. If transferring gigabytes of data the drives are mounted.
    Shawn Bockoven
  • Bob Woodhead
    May 19, 2005 at 6:04 pm
    I was checking out Omnibrain.com (they make 1394 drivers & hardware) – they say that using their drivers for 1394 gives slightly faster speeds via FW400 than gigabit ethernet. Using native 1394 drivers is slightly slower, so I’m going to guess that this method (just a cable, ma) is comparable to Gbit. No doubt more than a few peers would probably kill the speeds, due to packet collisions, etc, on an unmanaged network topology. But it’s great for those of us with just a few CPU’s.
  • Bryce Whiteside
    May 19, 2005 at 7:16 pm
    will griffith – IT blocked the macs from our PC network (security concerns)
    Inquiring minds…
    Bryce
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
  • Will Griffith
    May 19, 2005 at 7:18 pm
    That was my reply as well.
    I’m still trying to find
    some sort of meaning in it.
    -will
  • Peter Mcauley
    May 19, 2005 at 8:19 pm
    Personally it should be the other way around, when was the last time any of your macs had viruses?
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.3.8
    FCP 4.5 HD
    QT 6.5.2
    Kona 2 v1.1 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
  • Will Griffith
    May 19, 2005 at 8:23 pm
    It doesn’t matter how good our Macs are,
    what matters is they are not PCs.
    Facts have no relevance here. Only name brands.
    -will
