Final transition has a black page before transitions begins….
Dawn Raine replied 12 years, 5 months ago 3 Members · 15 Replies
Graham Bernard
March 19, 2014 at 4:44 pmAh, righto! – From reading your “grab”, you’ve appeared to have extended the Event from A >>> B and have created a Loop. You haven’t done this in the piece below ‘cos you have Stretched it instead.
What do you think now?
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
John Rofrano
March 19, 2014 at 5:01 pmYou can’t extend the edge of the event. That’s what’s causing it to loop. You need to physically move the entire event to the left to make the overlap.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Dawn Raine
March 19, 2014 at 8:04 pmIn the second grab is the one where I have the area of black before the transitions. That I do not want.
O.k… I deleted everything and started over. So let me ask this?
I put the events in one at a time. I time stretched every other event.
Each event is bumped up next to one another. No overlapping done by me.
I checked each one over and over again. No events are moved over the other.
I do have the automatic crossfades highlighted up on the top toolbar.THEN…I select all and added my transitions…bad news…same results.
I am getting close to giving up. But I am too stubborn for that.I have read and watched just about every tutorial that I can find.
Meanwhile the laundry is piling up! LOL -
John Rofrano
March 19, 2014 at 9:46 pm[dawn raine] “No events are moved over the other…. THEN…I select all and added my transitions…bad news…same results. I am getting close to giving up. But I am too stubborn for that.”
Your problem is that you have the events end-to-end with no overlap. A transition REQUIRES that they be overlapped. You need to overlap each event by moving them over each other for the duration of the transition. Then you can apply transitions other than the default crossfade.
~jr
Dawn Raine
March 22, 2014 at 9:29 pmOk…Thank you.
I will try that next time I mess with it.
I actually got frustrated and decided to take a break.
That is hard to do as I am normally pretty stubborn.
Thank you guys!
Dawn
