Activity › Forums › Apple Final Cut Pro Legacy › Final Cut Pro makes TEXT images look like ctrap!
Elijah Lynn replied 17 years, 7 months ago 6 Members · 13 Replies
Elijah Lynn
February 3, 2009 at 2:11 amI had this problem as well with some Livetype and FCP. On playback and render the text would tear and be jumpy all over the place.
I eventually was guided by David Weiss towards the built in Boris 3D text tool. Worked like a charm!
Nick Toth
February 3, 2009 at 3:22 amYour problem is most likely because the project properties in Livetype are the default settings which are CCIR 601 720 X 486. You can change them to be formatted properly for a DV sequence. (DV NTSC 3:2, 720 X 480, lower field dominant) Then it will work fine. Your Livetype settings must match your FCP sequence settings. It’s not a problem with FCP.
NT
