Activity Forums Apple Final Cut Pro Legacy Final Cut Pro & BWFs
  • Ryan Krickow
    February 18, 2009 at 5:04 am
    Andreas,
    I downloaded the trial version and ran it through some tests. The self-contained Quicktime files with the XML are perfect! I still have a few general questions…
    1. Does the OMF contain all the XML metadata?
    2. In what instances would I want the file extension to be .wav vs. .mov? Are there particular programs that won’t accept .mov files?
    3. Finally, to my knowledge I wasn’t able to get the Data Mapping function to work (I didn’t see any metadata info when I opened up a clip using the “New Setting” button-only category headings and
    “–“). During my testing I was working with a BWF audio file I downloaded from the internet that should have had metadata, I’m just not sure how to access the info through the BWF2XML program and I wonder if it’s just the audio file I’m working with. If you know of any sample BWFs I could get ahold of that would be a great help!
    Thanks so much, the program seems to be just what I’m looking for.
    -Ryan
Page 2 of 2
