Activity Forums Apple Final Cut Pro Legacy Final Cut Pro 7 wishlist
  • David Roth weiss
    May 9, 2009 at 3:24 pm
    [walter biscardi] “Sure you have to prep the timeline to get rid of stills and speed changes, but once you work out that workflow, it’s quite easy. “
    Nope, that’s simply not acceptable. Prepping of any sort has to go. “Baking in” should be reserved for agoraphobic cooks. And, I can’t be persuaded otherwise, so don’t bother trying.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Walter Biscardi
    May 9, 2009 at 3:44 pm
    [David Roth Weiss] “Nope, that’s simply not acceptable. Prepping of any sort has to go. “Baking in” should be reserved for agoraphobic cooks. And, I can’t be persuaded otherwise, so don’t bother trying. “
    I wouldn’t bother trying to convince you. People keep asking me how I keep growing my business while so many people seem to be having a slow time. This is one way. I accept that not everything is going to be as easy as pushing a button. Sometimes you actually have to work a bit to make a product better or to please a client or to create new job opportunities where you didn’t have any. Color enhancement is one job opportunity that has opened up thanks to Final Touch / Color.
    I find it completely acceptable to have a company that grows in business by 200 to 400% each year and accepting the workaround needed for Final Touch / Color is one way we’ve done that.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • David Roth weiss
    May 9, 2009 at 3:59 pm
    None of this is germane to this discussion, which is about what needs to be fixed in Color.
    I happen to like Color, a lot even, but the XML or other file transfer protocol it uses needs to be made completely seamless. When that happens Color will be light years of where it is today.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Walter Biscardi
    May 9, 2009 at 4:13 pm
    [David Roth Weiss] “None of this is germane to this discussion, which is about what needs to be fixed in Color. “
    More formats, Stills and if possible, speed changes. That’s what needs to be fixed in Color.
    Read my Blog!
  • David Roth weiss
    May 9, 2009 at 4:26 pm
    [walter biscardi] “More formats, Stills and if possible, speed changes. That’s what needs to be fixed in Color.
    Bingo!!! Now we’re talking… I have no problem with making it perfect, and that’s essentially all it would take.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Rafael Amador
    May 9, 2009 at 4:35 pm
    Sure few little things could be improved in the Color’s interface, but no may. I think is very good.
    But what I dream is with Color working inside FC. As Color-Finesse can do.
    Another think that could be improved is being able to alter the pipeline. Some times would be interesting apply certain effects before the CC.
    And the last thing I want ask Apple is, please, support third part codecs.
    I want Color ingests and exports Sheer.
    rafael
    http://www.nagavideo.com
  • Walter Biscardi
    May 9, 2009 at 5:44 pm
    [Rafael Amador] “But what I dream is with Color working inside FC. As Color-Finesse can do. “
    The would just dilute it to a plug-in. Don’t see how you can pack a Primary In, 8 secondaries, Color FX, Geometry, Primary Out rooms into a plug-in. Looks is as close as you can get and it’s just too limiting.
    Of course you can do a primary grade using the 3 Way CC tool and Color will pick it up. What I would expect is that the 3 Way CC tool will get a facelift, or we’ll see a Color type of plug-in added so you can do quick and easy CC or do a “primary color grade” in FCP which will then be completed in Color.
    [Rafael Amador] “And the last thing I want ask Apple is, please, support third part codecs.
    I want Color ingests and exports Sheer. “
    It does already. DVCPro HD, XDCAM and RED are all third party and all can go into Color. What Color needs is the ability to work with more codecs and I honestly have no idea if it will or if it should.
    Read my Blog!
  • Chris Karageorgiou
    June 6, 2009 at 5:03 am
    I small request would be an “in use” tick column in the browser window for clips that are being used in a sequence. It’s a minor addition, but it would save me some time.
  • Tom Wolsky
    June 6, 2009 at 9:36 am
    Used in which sequence? What if it’s more than one sequence? What if you nest sequences?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Jack Bibbo
    June 10, 2009 at 3:40 am
    Maybe late to the game:
    Better Trim tools. – More specifically better trim window.
Page 7 of 8
