Activity Forums Apple Final Cut Pro Legacy Final Cut Pro 6.0.6 problems
  • Miodrag Ristic
    April 28, 2010 at 6:37 am
    You must be right, they even call the setting SQUEEZED, but their explanation is misleading; “extracting 4:3 shaped patch out of the center…”
    Mio
    http://www.digitalvideovault.com.au
  • David Almond
    April 28, 2010 at 12:27 pm
    Our sequence settings are DV Pal 48Khz Anamorphic
    Is this a known issue in Final Cut Pro 6.0.6 or is it something we should be able to solve. We do have a workaround but would love a fix!
    Thanks for your help 🙂
  • David Roth weiss
    April 28, 2010 at 4:54 pm
    [david almond] “Is this a known issue in Final Cut Pro 6.0.6 or is it something we should be able to solve.”
    David,
    Open your QT in Quicktime Player, go to Window>>Show Movie Properties>>Presentation, then check the Conform aperture box and change its drop-down menu to “Production,” then do a File>>Save. From now on that QT will open properly as anamorphic widescreen.
    Good luck,
    David
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • David Almond
    April 29, 2010 at 8:48 am
    Hi there,
    Thanks for your reply.
    We already have this in operation, wherby they export then go into quicktime.
    We really need a definative answer to if you should be able to export as 16:9? Or is this a known bug in FCP 6.0.6.
    As our students \ staff only see the quicktime fix as a workaround for now?
    Dave
  • Rafael Amador
    April 29, 2010 at 10:32 am
    This not a bug and is the oldest and well known issue of QT.
    By default QT display everything as Squared Pixels.
    Thus when playing 16×9, looks like 4×3. But neither is 4×3.
    Solution: Whatever you do to be played in a computer, do it with Square pixels. You’ll never have more distortions.
    rafael
    http://www.nagavideo.com
Page 2 of 2
