Activity › Forums › Apple Final Cut Pro Legacy › Final Cut not reading correct Timecode using footage from Media Encoder
Jon Chappell replied 14 years, 8 months ago 5 Members · 16 Replies
Jeremy Garchow
January 27, 2012 at 9:25 pm[Brian J. Smith] “If Compressor sees the correct TC info, is there perhaps a way to know what Compressor looks at vs FCP?”
It must be stored in some blackbox QT metadata somewhere, but it’s not showing up in the true “timecode” track. Doesn’t show up in AUX TC.
I don’t know enough about it either.
You might want to contact Digital Rebellion as well. Smart folks over there, and point them to this thread.
By the way, Modify Timecode works for me in FCP. You would have to add the reel too.
Jeremy
[Brian J. Smith] “Someone on the Adobe forums suggested we use Premiere (in this case not an option) though it would solve our issues.”
Well, I wonder if Premiere will somehow write the correct information in to the QT files. That would help a lot. Not sure if it will do that, though.
Bouke Vahl
January 29, 2012 at 1:51 pmWell,
I’ve added an option to QTchange to refresh the TC track.
(it takes the found start time and reelname, and writes a fresh tc track based on that, with the choosen FPS, so make sure that matches!)Let me know if this fixes things.
Bouke
https://www.videotoolshed.com/
smart tools for video pros -
Brian j. Smith
January 31, 2012 at 3:39 pmJeremy, thanks for suggesting Digital Rebellion. They came up with a modification to their already amazing Pro Media Tools that did the trick. I cannot thank Jon enough for his quick work and generosity in solving this one for us.
https://www.digitalrebellion.com/contact.html if you are interested in their fix and/or more about their other products.
Jeremy Garchow
January 31, 2012 at 5:37 pmSweet, Brian. Glad they got you sorted. Jon Chappell does a great job.
Jeremy
Kevin Monahan
January 31, 2012 at 9:36 pmThis doesn’t sound right. I’ll forward this post to the AME team. Thanks for reporting on it and thanks to Jon for the fix.
Kevin Monahan
Sr. Content and Community Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
Jon Chappell
January 31, 2012 at 9:38 pmKevin, I’d be happy to send you or another Adobe employee the technical details if that would help.
My software:
Pro Maintenance Tools – Tools to keep Final Cut Studio, Final Cut Pro X, Avid Media Composer and Adobe Premiere Pro running smoothly and fix problems when they arise
Pro Media Tools – Edit QuickTime chapters and metdata, detect gamma shifts, edit markers, watch renders and more
More tools…
