Activity › Forums › Apple Final Cut Pro Legacy › Final Cut 7 stuttering playing prores 422 LT
Aaron Fisher-cohen replied 13 years, 11 months ago 5 Members · 12 Replies
Aaron Fisher-cohen
October 25, 2012 at 1:36 pmIt’s a WD Caviar Black 7200 6Gb/s drive. Should not be in issue at all and like I said, I can play higher bit rate stuff from that drive no problem. It’s only about a third full.
I do have a FW drive I can try, I’ll do that when I have a chance.
Aaron Fisher-cohen
November 1, 2012 at 1:57 amTo anybody following this thread, I figured something out…sort of.
After editing in Premiere for half a week without any issues, I came back into FCP to try some things out. I noticed that even though single clips stuttered like hell, a two-clip multiclip played flawlessly. This obviously made no sense at first. Then, I wondered if Final Cut was automatically lowering the playback quality for the mulitclip, so I set the timeline to play at “medium” quality and, lo and behold, the single clips played fine, too.
So, even though I had my playback quality setting at “dynamic,” I guess FCP didn’t recognize that it had to play single clips at a lower quality. As soon as I forced it too, it seems to have worked.
I still think it should be able to play these clips at full quality without issue but this is good enough for now since I can’t really visually tell the difference anyway.
