Activity › Forums › Apple Final Cut Pro › FCPX produces color shift and gamut error on import
Chad Smith replied 8 years, 7 months ago 2 Members · 16 Replies
Jeremy Garchow
February 16, 2018 at 2:44 amIs your Library set for 709 vs wide gamut?
And have you updated the drivers of all of those devices (uninstall/reinstall)?
Chad Smith
February 16, 2018 at 3:17 amYes the library in FCPX 10.4 is set to REC 709 color space
All drivers are recent
Chad Smith
February 16, 2018 at 4:56 pmJust trashed FCPX all perfs, restarted and re installed FCPX 10.4
Same issue with Bars being out of spec
Jeremy Garchow
February 16, 2018 at 5:27 pm[Chad Smith] “Same issue with Bars being out of spec”
Did you uninstall and reinstall the AJA and or Blackmagic Drivers?
If that doesn’t work, have to written AJA support?
Jeremy
Chad Smith
February 16, 2018 at 7:05 pmThe AJA T-Tap out of FCPX 10.4 is displaying bars correctly now. So re installing FCPX 10.4 has fixed the problem with the AJA device.
However the bars are still out of spec when using BMD UltraStudio Mini Monitor and UltraStudio 4K Extreme. This is with the current BMD driver 10.9.11
