Activity › Forums › Apple Final Cut Pro › FCPX messing with GarageBand files
  • FCPX messing with GarageBand files
    Posted by Kent Wiley on February 9, 2025 at 10:37 pm
    Anybody heard of this? I’ve brought a few pieces of sound from GarageBand into FCP 10.7.1 and they are being mercilessly modified. The files sound fine in every other player: Finder; Audacity; VLC; Quicktime. Is it the 44.1 kHz sample rate that GB saves them in, and FCP expects 48 kHz? BTW, it’s a known fact that GB cannot save files in anything but 44.1 kHz. Conversion from 44.1 kHz to 48 kHz in Audacity doesn’t solve the problem.
    Thanks for any suggestions!
    Brie Clayton replied 1 year, 7 months ago 4 Members · 13 Replies
  • 13 Replies
  • Devrim Akteke
    February 10, 2025 at 8:29 am
    Not an active Garage Band user but I remember you can set it up as 48Khz in Project Setup Window. And did you export it as an AIIF or WAV or mp3. All should be ok but mpeg encoding and decoding may cause a problem. At least I remember problems in the past. And if it is 44.1, did you make your FCP timeline 44.1, too?
  • Kent Wiley
    February 10, 2025 at 5:20 pm
    Thanks for your reply, Devrim. As far as I can see, and from what I’ve read elsewhere, GB does not allow 48 kHz resolution files. So it’s not an option. I would have done that at the start, if I could have. The files were exported in all formats (WAV, mp3, AIFF, AAC), and all of them are messed up. The FCP project was started months ago in 48 kHz, and all my other sound files are at that rate, so it’s not an option to change there. Any other ideas?
  • Doug Metz
    February 13, 2025 at 11:41 pm
    “I’ve brought a few pieces of sound from GarageBand into FCP 10.7.1 and they are being mercilessly modified. The files sound fine in every other player: Finder; Audacity; VLC; Quicktime.“
    Hey Kent,
    Can you clarify what ‘mercilessly modified’ entails?
    Do you have a copy of Media Info or Invisor?
  • Kent Wiley
    February 14, 2025 at 8:19 pm
    Hi Doug,
    I do not have either of those apps. Hard to describe how the files sound different. How to write about sound? Pinched? Distorted? But how…Not very helpful. Missing frequencies. The problem lies within FCP, it seems. Everywhere else, they sound fine. I’m going to create a FCP project that is 44.1 kHz and import the GB files, see if that changes anything.
  • Doug Metz
    February 14, 2025 at 8:55 pm
    What you’re describing sounds like phase cancellation, maybe due to misinterpretation by FCP as to what’s actually in the file.
    The reason I mention those two apps is that they give far more detailed information about the contents of your media files. Invisor is only $5, and will be more useful than you think.
    In any event, this section of the user guide details how to change the channel configuration, and when/why you might need to:
    https://support.apple.com/guide/final-cut-pro/configure-audio-channels-verc1fab5f6/mac
  • Kent Wiley
    February 14, 2025 at 9:05 pm
    Whoowho! That was indeed the solution. Changed the configuration to “Reverse Stereo” and it sounds fine. I know about the channel config but never thought to look over there for music. Many thanks Doug. I think you’ve saved me from buying Logic.
  • Doug Metz
    February 14, 2025 at 9:29 pm
    Awesome – glad I could help!
  • Kent Wiley
    February 14, 2025 at 9:40 pm
    But I wonder about the page of the guide you linked to. It shows even as far back as FCP 10.5 there is an option for mono, stereo, and surround. I’m still running 10.7.1 and there is no surround option, but there is the reverse stereo. When the audio is imported and selected in the browser, these options change?
  • Doug Metz
    February 14, 2025 at 9:55 pm
    Yes. Since you’re looking at the properties of an individual clip, FC shows you available options based on what’s in the file, as opposed to your projects where you get to determine the output (whether you have the channel coverage or not).
    You can import surround / multi-channel audio files (many of the included SFX are surround files).
    Edited because the Cow’s reply box totally hogs the screen and won’t let me review the message I’m replying to while I type.
  • Kent Wiley
    February 14, 2025 at 10:09 pm
    Good to know.
    Yeah, what’s w/ the Cow’s reply box that won’t allow viewing the message you are responding to? Mine goes almost totally white beneath the reply box.
