Activity › Forums › Apple Final Cut Pro › FCPX cunning workflow: so close yet so far!
  • Brett Sherman
    May 4, 2014 at 10:13 pm
    [Jeremy Garchow] ”
    If you shoot 1TB, have that on your drive, then import and rewrap, it adds another 1TB.”
    That assumes you keep the camera originals files. I understand why people do this. We don’t. I don’t find it worth the extra storage space. We just rewrap and once we’re sure everything is there, erase the camera cards.
    Incidentally, I have had as much trouble with people doing incomplete transfers with camera cards as I’ve had with rewrapped files. So I’m not sure it’s much of a fail safe.
  • Jeremy Garchow
    May 5, 2014 at 12:30 pm
    Even when transcoding, I always keep shoot media as it is the master copy.
    I didn’t throw away tape after I captured it either.
  • Bret Williams
    May 5, 2014 at 3:42 pm
    Not only that, we have multiple copies/clones of those original camera files. Sure we delete the cards when it’s time for another shoot. But along the way there’s a copy on the raid (that gets imported and rewrapped), a copy on the USB drive from the shoot, often a copy on the laptop from the shoot, and a copy on a backup drive eventually that gets stored off site in case of fire or theft.
  • Robin S. kurz
    May 6, 2014 at 8:26 am
    “In the case of XAVC, it doubles it.”
    Odd that I’m not in fact seeing that here with my XAVC material, nor have I ever.
  • Jeremy Garchow
    May 6, 2014 at 11:55 am
    When you import 128GB of XAVC, the resulting rewrapped QTs are not 128GBs?
    The original 128GBs x the rewrapped QT movies = 256GBs
    This is double the disk space.
Page 2 of 2
