Activity Forums Apple Final Cut Pro FCPx and Mac Pro performance
  • Noah Kadner
    October 19, 2015 at 4:37 am
    Also I’d look at network connectivity- make sure you’re not running constant backups/dropbox over a slow connection. Also make sure to optimize Thunderbolt port usage:
    https://www.fcpworks.com/thunderbolt-bus-mapping-new-mac-pro/
    Noah
    FCPWORKS – FCPX Workflow
    FCP eXchange – FCPX Workshops
  • Andrew Johnson
    October 20, 2015 at 10:52 pm
    There is a 3rd party fix that might be applicable to you and your situation and I found it while just browsing the apple store a couple of years ago.
    Alsoft Disk Warrior
    This software does to mac what disk defragmentation does to PC. We forget sometime that at the end of the day a Mac is a computer that needs to be cleaned up at times. If you are an editor, and graphics designer, photographer or audio person, we often delete and import a lot of files and forget that that causes out system (Mac or PC) to have gaps in the operating system which causes it to slow down tremendously. If you follow the instruction on the disk of Disk Warrior, this should help you quite a bit. Wish you the best
    Semper Fi
    Andrew Johnson
    Director/Videographer
    770-866-5457 – Mobile
    404-462-3207 – Office
    number1videoman@yahoo.com
    “What We Do In Life Will Echo In Eternity”
    Semper Fi
    Andrew Johnson
Page 2 of 2
