Activity › Forums › Apple Final Cut Pro › FCPX 10.4.2 not recognizing transparency in ProRes 4444
  • Michael Angelo
    August 21, 2018 at 7:13 pm
    The proxy swap for a QT 444 @ 960×540 worked, less than elegant and makes collaboration with remote editors a little funky but it’s a great short term work around thank you!
    Much gratitude to Creative Cow and everyone including Jeremy that chimed in, cheers.
    MA
    Harvest the compromises…
  • Jeremy Garchow
    August 21, 2018 at 7:16 pm
    [Michael Angelo] “The proxy swap for a QT 444 @ 960×540 worked, less than elegant and makes collaboration with remote editors a little funky but it’s a great short term work around thank you!”
    You don’t have to change the resolution if you don’t want to. you can just keep the native resolution.
    I usually copy (option-drag) the files from my normal directory to the proxy directory. This will cut down on media duplication.
    If you are trying to save file size, then yes, a 960×540 444 movie will work too.
    Jeremy
Page 2 of 2
