Activity › Forums › Apple Final Cut Pro › FCPX 10.1 video not showing in timeline, but fine in Event Browser
  • Jungsuk Kang
    March 26, 2017 at 1:38 am
    This month I have encountered same problem that Rosa Linda Román had. I somehow I just found solution below(you can skip no.1)
    1. I selected clip which not showing and copy-paste it to exact same position. So 2 same clips on timeline. doubled up.
    then It worked. Clip is showing with no problem in viewer. So I deleted 1 of them then It goes black again.
    2. So I tried many other things, then found solution. Select your clip and right-click. choose “overwrite to Primary Storyline”
    then mine worked completely. No hassle.
    I hope you too solve this problem. Hope this method work for you.
Page 2 of 2
