Activity › Forums › Creative Community Conversations › FCP-X for documentaries (with details)
  • Brian Seegmiller
    October 2, 2015 at 2:31 pm
    So it is not that FCP X can’t do what they wanted but that Resolve could not. So can you send a Premiere Pro project to resolve with a Ken Burns effect Aindreas Gallagher?
  • Jeremy Garchow
    October 2, 2015 at 4:25 pm
    [Bret Williams] “You can’t ease anything in FCP X.”
    FCPX has velocity controls, but they are convoluted and weird. This was made in FCPX all with position keyframes and velocity control.
  • Bret Williams
    October 2, 2015 at 4:33 pm
    Did you do that with the workaround where you add a keyframe, then delete it?
  • Herb Sevush
    [Jeremy Garchow] “FCPX has velocity controls, but they are convoluted and weird. This was made in FCPX all with position keyframes and velocity control.”
    Can you control both scale and position the same way?
    Herb Sevush
    Zebra Productions
    nothin’ attached to nothin’
    “Deciding the spine is the process of editing” F. Bieberkopf
  • Jeremy Garchow
    October 2, 2015 at 4:37 pm
    No, I use the little nubs on the path in the Viewer.
  • Jeremy Garchow
    October 2, 2015 at 4:54 pm
    [Herb Sevush] “Can you control both scale and position the same way?”
    I said it was convoluted and weird, not supercool fantastic.
  • Bret Williams
    October 2, 2015 at 5:20 pm
    Can you clarify? All I can get them to do is spatial. Curves (smooth) or linear. Seems like in some version I was able to trick it into easing, but not lately.
  • Andrew Kimery
    October 2, 2015 at 5:23 pm
    [Tony West] “I have never used that program so I can’t say, but most of my footage came from a site called critical past.”
    I’ll check out critical past. You can never have too many footage sites.
    [Tony West] “I stuck mostly with stills from the DOE, NRC or other government agencies. If it belonged to the government I knew I didn’t have to pay for it.”
    I try to use my already spent tax dollars effectively too! One thing that I have seen though is commercial stock footage/image sites taking material that is public domain and charging for it like they own the rights.
  • Jeremy Garchow
    October 2, 2015 at 5:26 pm
    You click on a point, and you get the little beizer type handles. Hold shift, and drag that handle either left or right. That changes the size of the little hash marks of the path, which in turn changes the velocity of the clip. If you do it on both points, you can change the in and out speed.
    Here’s a lame diagram:
  • Bret Williams
    October 2, 2015 at 6:29 pm
    The shift is just to keep the bezier handle in line with the straight path, correct? Because it seems to work with or without shift. I’ve had this work on occasion in the past, and recently it wasn’t working. Possible it broke for a version or two?
    Alright, good. Good tell Aindreas.
    Now, to go see if that’s the trick in resolve. They removed the graphing for position in v12, and with it the ease controls for position.
Page 7 of 9
