Activity Forums Creative Community Conversations FCP X Colour Correction Pics?
  • Hector Berrebi
    June 13, 2011 at 12:39 pm
    [David Battistella]
    FCP is fast for breaking down the marble block but not as good at the detailed edits as AVID (was, and I mean was). “
    In my opinion, the only true advantages Avid trim tools have over FCP are:
    better play-loop options.
    avid stops at left of cuts, and trims and sees the left side of the cut (I hope version X will finally learn this complex maneuver) .
    and Avid behaves logically when trimming two sides that are not on the same track (FCP shows black on one side…).
    There obviously are other differences, but I don’t think they are crucial (like 4 screen display …)
    Beside these ,on current FCP, using a good keyboard layout and the trim tool, I am just as fast as I am on Avid. I even think apple added a few features to trim that Avid should look at adopting (multiple frame trim for one)
    I am curious… What avid trim options do you lack in FCP?
    hector
    Hector
    Hector Berrebi
    prePost Consulting
  • Hector Berrebi
    June 13, 2011 at 12:49 pm
    [Brian Mulligan] “Looks like more people should look at Autodesk Smoke. It has had integrated tools and a single viewer interface for years.”
    🙂 SMOKE has been my new escape plan for a while …
    I really like what it has become in past years, and it trully earns its “high-end” badge.
    Price is still a turn-off so are requirements (at least when comparing to the others)
    But I’m definitely looking in to it more and more
    Hector Berrebi
    prePost Consulting
  • Walter Soyka
    June 13, 2011 at 1:01 pm
    Brian, are you suggesting Smoke for creative editorial as well as finishing?
    Walter Soyka
  • Brian Mulligan
    June 13, 2011 at 1:24 pm
    [Walter Soyka] “rian, are you suggesting Smoke for creative editorial as well as finishing?”
    We have 2 Smokes at WTHR-TV. We do anything from :10 spots to 1 hr. shows. We edit everything from scratch on them. We do the ditorial and the finishing at the same time. And if a change is needed, it’s easy, because it’s all in the box.
    Smoke is still a bit pricey… but it’s a solid program, with unmatched quality.
    Here is my latest reel, a bit graphic heavy.. but that’s how our work and style has developed. All in Smoke, except for the 3D [13] logo.
    https://youtu.be/F9-QT2enIPU
  • Oliver Peters
    June 13, 2011 at 1:26 pm
    Seems like a facility design based on FCP X, Resolve, Pro Tools (or Logic) and Smoke would be very good. FCP X for 80% of the work and all creative cutting. Smoke for the true finishing.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • David Battistella
    June 13, 2011 at 1:44 pm
    [Hector berrebi] “I am curious… What avid trim options do you lack in FCP?”
    I have always found going in and out of trim mode in FCP a bit, well, Clunky.
    I liked the four image trim in AVID, something FCP never really had.
    I’m as fast in FCP and I prefer it now because it has SO many advantages and the image quality is better.
    The scrubbing tool is better in AVID as well.
    David
    ______________________________
    Believe me. Everything is a lie.
  • Jose Lomeña
    June 13, 2011 at 2:19 pm
    Do you mix audio into Smoke?
  • Walter Soyka
    June 13, 2011 at 2:21 pm
    [Oliver Peters] “FCP X, Resolve, Pro Tools (or Logic) and Smoke would be very good. “
    It’s a pity Smoke has only three secondaries in the color corrector. Having to work Resolve into the workflow complicates it a bit.
    Walter Soyka
  • Misha Aranyshev
    June 13, 2011 at 2:29 pm
    First, Smoke has Source/Record layout too if you want it.
    Second, Insert/Overwrite is a mode in Smoke. Well it is a mode in almost every other editor but that’s just shows how with all the fuss we make online we still would settle for mediocre and outright stupid interface.
  • Oliver Peters
    June 13, 2011 at 2:30 pm
    [Walter Soyka] “Having to work Resolve into the workflow complicates it a bit.”
    You don’t HAVE to. FCP X and Smoke can each do about 80-90% of the grading that most editors will want. But if you are a facility that seriously sells color grading with the talent to back it up, Resolve is the best option in this price tier. There are two caveats, though. 1. No Color X is released, and 2. the (eventual) Baselight plug-in for FCP X doesn’t prove to be more powerful.
    – Oliver
    Orlando, FL
Page 3 of 8
