Activity › Forums › Apple Final Cut Pro › [FCP X 10.0.8] Best plugin (or techs) to fix Out of focus video
Drew Lahat replied 12 years, 2 months ago 13 Members · 27 Replies
Mark Smith
August 12, 2013 at 1:07 pmRight but …. the effects of solutions you try may can vary widely depending on the composition of the image… and by that i mean the contents of the frame. What might sort of work for one frame will be totally wrong for another frame
Duca Simone luchini
August 12, 2013 at 1:33 pmof course, but I’m going to try if I find an acceptable solution.
David Eaks
August 12, 2013 at 2:01 pmMy definition of “way out of focus” is probably much less out of focus than it sounded. That said, I’ve had both good results with NEAT and also been unable to get the results I thought I should be able to. Being able to build a good profile is important. If the image needs any noise reduction, you might even do two passes. One pass of noise reduction and an almost imperceptible amount of sharpening, then a real sharpening pass. Like Mark said, it all depends greatly on the composition and subject.
For example, a locked down shot of a talking head who has no hand gestures that go off the sides of the screen and is in front of a flat detail-free background. The image could be slightly scaled down and layered over another full size copy, crop and feathered to hide top and side edges, moved to the bottom of the screen and sharpened a little. Surely you don’t have this ideal situation though. Could you post a freeze frame from the video?
Duca Simone luchini
August 13, 2013 at 6:53 am -
David Battistella
August 13, 2013 at 9:48 amEnough people have lectured you in this thread about re-shooting which you have stated you can not.
This might be the best way to deal with the problem.
Perhaps you can try to put a soft mask on the image and sharpen only the face to the point where it is acceptable and then leave the background where it is.
You can do this easily in Resolve and adjust the softening sharpening parameters. Sharpen the inside a little (the face) and soften the outside more (the background) to create more of a separation.
Use a couple of nodes to achieve this effect.
David
______________________________
https://www.davidbattistella.com
Duca Simone luchini
August 13, 2013 at 10:00 amThanks David,
I (unfortunately…) have no experience with Resolve.
I’m going to try something in Neat Video. -
Brett Sherman
August 13, 2013 at 9:41 pmIf you haven’t missed the focus on occasion, you haven’t been in this business very long. The fact is, it has happened to everyone. Especially when you’re interviewer, camera person, audio person, and producer all at the same time.
Unsharp Mask is a good method for sharpening. It doesn’t come with FCP X, but Alex Goliner has a free one here.
https://blog.alex4d.com/2012/02/12/blurs-7-free-fcpx-effects/
Duca Simone luchini
August 14, 2013 at 5:20 amThe fact is, it has happened to everyone.Thanks Brett!
After this fact I bought a 7" control monitor and a View finder for my SDRL. Focus is too much important...! -
Duca Simone luchini
August 14, 2013 at 5:41 am -
Duca Simone luchini
August 14, 2013 at 8:16 am
