Activity › Forums › Apple Final Cut Pro Legacy › FCP Rendering Time
  • Chris Morlang
    May 9, 2011 at 8:23 pm
    Alright! When rendering 1920×1080 this is what Activity Monitor Displays:
    FCP is using 29 Threads and Average 1.6 GB Real Mem
    It uses 358% CPU Average
    65% By the User
    25% By the System
    10% Idle
  • Rafael Amador
    May 9, 2011 at 9:33 pm
    Hi Chris,
    [Chris Morlang] “It uses 358% CPU Average”
    IF FC shows a very low use of the CPUs that means that somewhere (System, drivers, plulgins..) there is something preventing FC working properly.
    In your case FC is using all the 4 cores so is working fine.
    The problems are on the time-line.
    [Chris Morlang] “It was originally set to DVCPRO HD when I started I changed it to AppleProRes to get 1920×1080(square pixels) instead of 1220×1080 (non-square pixels) but then my render times went through the roof.”
    Elaborate this change on size/pixels aspect, please.
    Is your sequence 1920×1080 SQ pixels?
    Is your footage 1920×1080 SQ pixels?
    If so, does the footage in the time-line has “Size100%” and “Distort > Aspect Ratio: 0”?
    rafael
    http://www.nagavideo.com
  • Chris Morlang
    May 9, 2011 at 9:49 pm
    It used to be:
    Frame Size: 1280×1020
    Aspect Ratio: HD (1280×1020) (16:9)
    Pixel Aspect Ratio: HD (1280×1080)
    Yes it is 1920×1080 Square.
    Yes it is as well.
    Yes it does
    ~Chris Morlang~
Page 2 of 2
