Activity › Forums › Apple Final Cut Pro Legacy › FCP RED BAR!!!
David Roth weiss
May 4, 2008 at 2:32 am[Joel Colthorpe] “Wow, thank you so much! I suspected Final cut would work under the right conditions. It just sounds like you need a professional set up being a professional program. I guess that’s why I don’t hear many professionals complaining about it?”
Actually you have nailed it Joel… FCP does in fact have a few more hardware requirements than a program like Premiere, and it requires a tad more knowledge and experience on some levels as well. By design, Premiere is a solution that Adobe wanted anyone at any level to able to use on any computer. Apple has gone in a slightly different direction.
[Joel Colthorpe] “Does anyone know any other fast options as far as media drives go? The ones previously recommended are good from what I have read but it would be good to have some options in case budget comes into it. I will be doing more research myself but it would be good to hear it straight from the cows mouth…”
Hard drives are among the most inexpensive computer components available now. A 500gb firewire 800 drive is probably a very good place for you to start. You can get a LaCie firewire 800 drive for about $160 that will do the job nicely until you need more speed and throughput later. ESATA is faster, but requires a controller card in additiona to the drive unit itself.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Joel Colthorpe
May 6, 2008 at 12:36 amThanks David, I’m sorry if I came across as insulting towards the program or it”s users, however, you might notice that any negative comments I was making earlier all ended in a question mark. I at no pointed stated that Final Cut sucked or anything like that, as if I had total knowledge on the situation. If I didn’t expect that Final Cut had answers to this problem I would not have asked this forum.
As for my “lack of professionalism”, I never had any in the first place, nor did I try and pretend I did. So if I have insulted anybody or made Final Cut users look bad because I am not a professional yet I am deeply sorry.
The fact is I am learning, I never said I was a professional, and I was making no attempt to pass my self off as one. I jumped on this forum to learn, not to stick my chest out.The actual reason I started this post was because I have a business partner who was making Adobe Premier sound very good and I figured that there would be more to it. It didn’t seem right that Final Cut could not play real time. I wanted to find out that this matter with Final Cut was not a flaw in the program but a mistake I was making.
I am very happy to have been enlightened on this matter and I am grateful to yourself and the others who have responded.
Thank you everyone!
