Activity › Forums › Apple Final Cut Pro Legacy › FCP ProRes Workflow
Benjamin Mckay
November 20, 2009 at 3:37 pmYes, DG now accepts HD h264 mov files on their Chicago dropbox. im in New Orleans and thats what we use for broadcasting HD.
“A Cult Of One”
Benjamin Mckay
November 20, 2009 at 3:41 pmAnother Question:
If I have ProRes SD footage. Is it better to work in a timeline that is set to “None” compression (which requires me to render the sequence) or to work in a sequence set to “ProRes”? When I render the footage in a “None” sequence and export the footage it looks better than prores, but the interlacing on movement is way more apparent than when exporting a prores 9at least it is on my cinema display). Now, when I upload to DG is this going to matter, or is it just the fact that i am not viewing this on a broadcast monitor? Also, the graphics appear cleaner when I use the “none” compression setting over a “ProRes” sequence.
“A Cult Of One”
Jeremy Garchow
November 20, 2009 at 4:19 pm[Benjamin McKay] “When I render the footage in a “None” sequence and export the footage it looks better than prores, but the interlacing on movement is way more apparent than when exporting a prores 9at least it is on my cinema display)”
Better where? Not on a broadcast monitor. None is 8bit RGB. ProRes is 10bit YUV and has an uncompressed quality. I’d stick with ProRes.
Jeremy
Benjamin Mckay
November 20, 2009 at 10:39 pmIf I change my sequence settings to no field dominance on the ProRes it seems to make the motion crisper as well as the graphics. will this effect broadcast at all?
“A Cult Of One”
Bill Scheerer
November 23, 2009 at 3:54 amJeremy is correct that the SD is mpeg, sorry for that one, I post all the HD stuff here not the SD. I will post the HD specs on Monday just in case they are useful for anyone.
Benjamin Mckay
November 23, 2009 at 10:08 pmIf I change my sequence settings to no field dominance on the ProRes it seems to make the motion crisper as well as the graphics. will this effect broadcast at all?
“A Cult Of One”
