Activity › Forums › Apple Final Cut Pro Legacy › FCP P2 Import changes frame rate
Jeremy Garchow replied 17 years, 1 month ago 2 Members · 20 Replies
Jeremy Garchow
August 12, 2009 at 7:46 pmThen you have set something up wrong. How big is your ‘Test’ clip?
Jeremy
Jeremy Garchow
August 12, 2009 at 7:48 pmPlease zip the file and upload it here. I’d like to make sure you really have 3:2 and not 2:3:3:2
Jeremy
Scott Devlin
August 12, 2009 at 7:51 pmsorry for being a noob on the forum…where do I upload it to?
Jeremy Garchow
August 12, 2009 at 7:55 pmLook right above where you write the repsonses and click the little icon that looks like a disk.
Once it’s uploaded, copy and paste the url in to your reponse.
Jeremy
Scott Devlin
August 12, 2009 at 8:01 pm -
Jeremy Garchow
August 12, 2009 at 8:18 pmOkay, it is definitely 3:2, the trick is in compressor, you click on the icon of the video and change the field dominance from Progressive to Upper so that Compressor knows that the clip you are sending is interlaced and not progressive.
Check out this file:
Jeremy
Scott Devlin
August 12, 2009 at 8:28 pmJeremy, that did the trick bro…
This goes to show that no matter how long youve been doing this stuff, there is always more to learn. I am going to throw the rest of the clips into compressor and convert them per your specs above, including the quantity limit. Thanks so much and I am sure we will cross paths again 🙂
