Activity › Forums › Apple Final Cut Pro Legacy › FCP dropped frames warning
Brad Mirman
April 30, 2010 at 1:49 amSo, then I should transfer all my Video and FCP folders from my two internal drives to external drives (to hold info since I am in the middle of a project) — then set the internal drives to Raid0 (which will erase everything) and then copy folders from the external drives back onto my internal Raid drives?
David Roth weiss
April 30, 2010 at 5:04 amJust do it!
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
EPK Colorist – UP IN THE AIR – nominated for six academy awards
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Brad Mirman
April 30, 2010 at 5:23 amDavid,
Okay, I’m doing it. I assume that copying everything to externals drives and back to internal raid is the correct way. Forgive my anxiousness, but I would hate to do it wrong and lose parts of my project.
Thanks for taking the time to walk me through this
Brad
David Roth weiss
April 30, 2010 at 5:39 amYou’ll be fine Brad, and once you succeed it will give you a tremendous feeling of confidence.
David Roth Weiss
Brad Mirman
April 30, 2010 at 6:06 pmOkay, what I’m thinking of doing is this: I will have 4 internal drives in my Mac Pro. I will do nothing to the MacHD OSX disk (drive 1). I will raid0 drive 2 and 3 to use as scratch disk and use the 4th disk as a backup.
I will also backup to external firewire 800 drives?
Does that sound about right, or should I raid drives 2,3 and 4 and use the external firewire drives for backups?
Does using 3 drives in the raid0 configuration give me more than just using 2?
Thanks again
