Activity › Forums › Apple Final Cut Pro Legacy › FCP and QT timecode discrepancy
Robert Longwell replied 18 years, 3 months ago 6 Members · 38 Replies
Robert Longwell
November 13, 2007 at 10:18 pmCorrect. If we export using plain old Export QuickTime movie with current settings, audio & video, all markers and make self contained then there is no TC track.
Robert Longwell
Jeremy Garchow
November 13, 2007 at 11:37 pmRobert, I don’t know what to say.
In the bottom left corner of the Quicktime window there’s some numbers that run. CLick on those and change it to timecode.
Are you looking at this on a machine with FCP, and if it’s not a machine with FCP, is a machine with QT Pro at least?
Jeremy
Robert Longwell
November 13, 2007 at 11:39 pmWell I’ve fixed the missing TC sequence export. Amazing what can get fixed when one deletes their FCP preferences!
So now that I have a TC track in my QT files, just as I suspected, they are not in sync with my FCP timeline.
Robert Longwell
Jeremy Garchow
November 13, 2007 at 11:51 pmTry trashing your quicktime prefs as well.
Make sure to quit QT before doing this.
Robert Longwell
November 13, 2007 at 11:57 pmNo dice. I know this is a larger problem than just my computer. I have numerous Macs and PCs all having the same issue with the data being off from the exact same QT file.
I’ve informed my Apple rep, I’ll see what he comes up with.
Robert Longwell
Jeremy Garchow
November 13, 2007 at 11:59 pmIs there any chance at all you can export 5 seconds or so and post it up to download? I want to take a look if you don’t mind.
Jeremy
Robert Longwell
November 14, 2007 at 12:09 amLet me see if I can find an external server to host it on…
5 seconds wouldn’t be much of a sample for drifting, it would need to be closer to 5 minutes.
Robert Longwell
Jeremy Garchow
November 14, 2007 at 12:16 amYeah, you’re right.
Sorry Robert, I still don’t get it.
Rafael Amador
November 14, 2007 at 2:33 amI can not remember that jeremy. But i just open some clips that I exported back in February 2003 (QT 5.x?) and all of them have their TC track.
Rafael -
Robert Longwell
November 14, 2007 at 2:50 pmJeremy,
You can download my project and output QT here (I’ll delete this in a couple of days):
https://www.robertlongwell.com/temp/Archive.zipIt’s just 4 minutes of color bars but here are the numbers I’m getting –
FCP:
Duration – 00:04:00:00
Marker 1 – 01:00:58:18
Marker 2 – 01:02:39:18
Marker 3 – 01:03:51:18QT:
Duration – 00:04:00:06
Marker 1 – 01:00:58:19
Marker 2 – 01:02:39:21
Marker 3 – 01:03:51:23If the file were longer, say 45 minutes, you’d see the drift getting farther and farther along. For this 4 minute sample the drift is pretty small but the inaccuracy is still unacceptable.
Let me know if you see the same numbers from my zip file.
Robert Longwell
