Activity › Forums › Apple Final Cut Pro Legacy › FCP 7 Advanced Color Correction
  • Nick Meyers
    January 18, 2016 at 1:13 pm
    hi dean.
    one possibility is that you haven’t adjusted your FCP user prefs. (under the FCP menu)
    he default number of audio tracks is 8, which is ludicrous.
    up them to 24 at least.
    filters use up track locations, so thy may have pushed you over the edge there.
    another possibility is that you are using mp3 or AAC audio.
    dont.
    it may work, but it may not, and you cant tell when it wont, it’s unpredictable,
    convert all audio for FCP to AIFF or WAV
    cheers,
    nick
  • Dan Caldwell
    January 19, 2016 at 11:39 pm
    Hey Nick: That was it. I was importing .mov files for experimenting and when I imported a wav file the the EQ filter behaved properly. Thank You very much. Dan.
  • Nick Meyers
    January 21, 2016 at 10:15 pm
    Hi Dan.
    you do know that FCP prefers ProRes, and a few other standard codecs?
    it doesn’t like h264 or other lightweight codecs.
    if you use them, you may be ok, but you may also have issues: sync, weird exports, clicking sounds, etc.
    nick
Page 2 of 2
