Activity › Forums › Panasonic Cameras › FCP 6.0.4 and P2 Import install not working
Rob Sonner replied 17 years, 11 months ago 5 Members · 24 Replies
Richard Herd
September 30, 2008 at 4:05 pmHave you confirmed there’s media in the folder?
I’ve had this happen when there is very little media in the folder, probably because I hit the record on-off button too fast.
See if there’s video in there and -I to see the file size.
Rob Sonner
September 30, 2008 at 5:14 pmYes, there is video in the folder. I have successfully imported it into FCP 5.1.4 and previous drivers ok. The media is fine. thanks for checking, i ruled that out early on.
Rob Sonner
September 30, 2008 at 6:42 pmYes, that is the file I downloaded and installed. Hasn’t worked on multiple copies of FCP so far. Even did a fresh install of it on a system that hasn’t seen FCP before and still didn’t work. But this all still works well under FCP 5.1.4
