Activity › Forums › AJA Video Systems › FCP 5.1.3
  • Jeremy Garchow
    February 20, 2007 at 4:03 pm
    [walter biscardi] “Actually hurt my shoulder pitching too hard in baseball! :-)”
    At least you haven’t joined the ranks of pre teens who have thrown the Wii controller through Daddy’s big ole 1080p plasma!
  • Walter Biscardi
    February 20, 2007 at 4:09 pm
    [JeremyG] “At least you haven’t joined the ranks of pre teens who have thrown the Wii controller through Daddy’s big ole 1080p plasma!”
    that’s because it’s MY plasma and I keep those wrist straps tight! 🙂
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Oliver Peters
    February 20, 2007 at 4:41 pm
    [JeremyG] “If you have any suggestions on this workflow that I have been trying to nail for the past couple of years, I am all ears.”
    Jeremy,
    When Premiere Pro on Mac Intel comes out this year, you’ll have interop between AE and PPro. Might be an option worth investigating. In theory, you could cut in FCP, export to AE via AD and then bring the AE stuff back into PPro for color grading and final assembly. Of course, I’m not sure if this will work cross-platform.
    Sincerely,
    Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Jeremy Garchow
    February 20, 2007 at 4:49 pm
    Thanks, Oliver. It’s number 4 on my list of alternatives. I am very curious about Premiere on the Mac, but only if AJA will support it. If it all works, it would be the perfect solution to these kinds of jobs.
    Jeremy
  • Oliver Peters
    February 20, 2007 at 4:57 pm
    [JeremyG] ” I am very curious about Premiere on the Mac, but only if AJA will support it”
    I can’t imagine that they wouldn’t because there is already support on the PC side.
    Sincerely,
    Oliver
    Orlando, FL
  • Bart Harrison
    February 20, 2007 at 5:08 pm
    Wally,
    What do you use as a “client” confidence monitor ?
    Bart
    Bart Harrison
    MPA – The HD Suite
    America’s VAR
    TurnKey Editing Systems, Storage Area Networks
    HD Consulting, Production & Post, Exhibition & Distribution
    http://www.hdsuite.com
    954-894-1221
  • Walter Biscardi
    February 20, 2007 at 6:30 pm
    [Bart Harrison] “What do you use as a “client” confidence monitor ?”
    Sony PVM20L5/1 in one suite and the PVM14L5/1 in the other. One room has the 50″ Panny plasma and the other has the 42″ which is what we generally use when clients are here for editing and reviews.
    The Wii / Xbox 360 is a cheap Vizio consumer plasma screen, in case you’re wondering. 🙂
  • Erik Lindahl
    February 21, 2007 at 9:34 pm
    Eventhough this is totaly off topic I’m looking for exactly the same thing Jeremy G is – a round-trip solution from FCP to AE. We do a lot of FX and compositing-shots for adds and such. My work-flow usually is
    1. Offline-edit in FCP (DV)
    2. Online-edit in FCP (10-bit SD generally)
    3. Color Correction tend’s to be done in FCP with the built in tools. Works like a charm usually.
    4. Effects are done in either Shake or AE.
    It’s step 4 that is ha hassle if step 3 occurs, which it tends to do. Someone should come with a solution to send a complete edit to AE from FCP WITH the effects intact. If they might be rendered, that’s quite fine by me. But the best solution would be to have them brought into a plugin with also lives in After Effects.
    Actually the above is my biggest issue today in my workflow. It tends to make me render out intermediates from FCP and export / import like hell to AE. Not good I must say
  • Jeremy Garchow
    February 21, 2007 at 9:38 pm
    I knew I wasn’t the only one.
    Jeremy
Page 2 of 2
