Activity › Forums › AJA Video Systems › FCP 10-bit capture problem
  • Bob Zelin
    April 5, 2007 at 9:56 pm
    It can’t be a RAID 5 – each side (each group of 7 drives) must be RAID 5, and both sides (both volumes)must be raided together with Apple Disk Utility to be RAID 0 (striped, OS-X Extended – and NOT JOURNALED !!!!!!). All of this is VERY important, or it will not work.
    Check that Cache Flushing – this is critical. You can have everything set up correctly, and if you have Cache Flushing turned on, it will not work !
    Bob Zelin
Page 2 of 2
