Activity Forums Adobe After Effects falling leaf/paper effect
  • David Bogie
    July 27, 2007 at 2:32 pm
    Back in the olden days, long before Expressions, I used Sphere and Cylinder to do snowfalkes, leaves and feathers. A leaf wrapped around a Cylinder layer can be animated, with some care, to have truly convincing aerial ballistics. Doing it in 3D is more of a challenge.
    Nowadays you could use Shatter and Foam, too, but those require precomping movies to become the particles. A bit of a challenge for noobies.
    bogiesan
  • Darby Edelen
    July 27, 2007 at 10:29 pm
    I’m confused about why you need to mask anything. It sounds like this is a top down perspective of photos floating to rest on a flat plane? Where does the masking come in?
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Atomicrabbit
    July 30, 2007 at 2:32 pm
    Sorry, I didn’t explain that properly, I want to use a mask because I don’t want the full picture showing. When the picture is first shown, it either zooms in/out or pans left/right/up/down (for a nicer effect then just a static photo). That is why I need a mask, I am using an alpha matte for the “mask”. With the shape layer as a parent to the photo layer.
  • Atomicrabbit
    August 2, 2007 at 3:23 pm
    any suggestions??
    *atomicrabbit
  • Arul Mani
    May 30, 2009 at 7:34 am
    plugin sent my id
  • Luke Luxor
    September 26, 2010 at 5:29 pm
    Why cant i get that second link? I keep clicking and it keeps saying “server not found”! I understand what that means and I noticed every time i go to click on it the url changes to something completely different! HELP ME!
  • Salvatore Compagnone
    May 3, 2017 at 1:41 am
    Hi there.. ate there any expressions that you know of that can be applied for a layer that falls from behind the camera to a flat surface and not from the top of the frame. I.e. I imagine the scale of the layer would be animated instead, and how to stop the expression after it gets to the size you want it.
Page 2 of 2
